06-10-2015, 12:16 PM | #1 |
Rep 232
F30 335i OEM rear calipers & rotors great upgrade for 320/328/428 xdrive
$300+ actual shipping cost via paypal or cleared check/money order OR $300 cash with local pick up. Complete set of low mileage OEM rear brake set from an F30 335 M-sport with a lOt of life left (see 20mm rotor thickness dial caliper measurements, basically no measurable wear). These are the standard 330mmx20mm rotors and single piston floating calipers (not the upgraded M-perf). Includes left and right rear calipers and pads and left and right rear rotors. Pads are approximately 95% remaining life. Rotor hats have been painted black with high temp VHT (look ma, no more corrosion!). Rotors were properly painted with attention to prep, detail, and heat treating to provide for chemical resistance and maximum paint adhesion and longevity. For a glossier appearance buyer may choose to clear coat (I wanted more of a medium-flat appearance). These would be great for a 335 owner that is tired of the rusty rotor eyesore look and doesn't want to deal with painting and a car up on jacks during the paint process. Just swap and go. Also great for 320/328i/428i xdrive owners with the larger parking brake looking for a big brake upgrade on the cheap. These fill out the gap in 18" and larger wheels nicely. Plug and play with your existing rear knuckles, OEM caliper bolts and brake lines. These fit under ALL F30 OEM wheels. Prefer to sell as complete set but will split if both buyers are lined up. Just cleaned these and will grease pads with high temp synthetic brake grease for complete drop in assembly or leave dry if you are painting or powder coating. Just let me know. Please verify fitment, if unsure, PM. Install/upgrade is very straightforward and all OEM parts so no worries about warranty headaches...
2016 528i Msport/Premium/Drivers Assist II/ACC/Cold Weather/Harmon/Pwr trunk
2012 Kawasaki ZX10R ABS 1978 Honda CB750k, 1977 Yamaha XT500 1975 BMW R90/6 & 1969 R69S Last edited by hevykevy420; 08-31-2015 at 03:23 PM.. |
06-15-2015, 11:10 PM | #3 |
Rep 232
Caliper pics
2012 Kawasaki ZX10R ABS 1978 Honda CB750k, 1977 Yamaha XT500 1975 BMW R90/6 & 1969 R69S |
07-10-2015, 10:47 AM | #4 |
Rep 232
^bump^
08-31-2015, 03:23 PM | #5 |
Rep 232
^Price Drop^
