2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes For those of you who got rid of EDC
      06-11-2015, 03:21 PM   #1
Liquidpaper
Liquidpaper's Avatar
Drives: '15 M235i
2015 BMW M235i  [0.00]
For those of you who went for coilovers or some other setup that does not use the BMW EDC system, how did you do this without getting a warning light from the car?
Is there some sort of dummy plug you can use to make the car think it still has adaptive dampers installed? Thanks.
      06-11-2015, 04:46 PM   #2
kd0t
137
Drives: M235i
When I got my car coded from Frogman, he said you can code it off. He said he did it for someone on 2addicts recently.
      06-11-2015, 05:39 PM   #3
Mjosh
Drives: E46 M3
+1 interested in this as well!
I've been searching awhile in regards to EDC and not sure how to tell if we have this option or not. Another member did say it was standard on the 235 but I dont recall seeing it on the window sticker?
      06-11-2015, 07:09 PM   #4
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
it's standard but it's not like on other models where you have a dedicated EDC button.... this one gets bundled into the Sport mode setting
      06-11-2015, 08:36 PM   #5
Mjosh
Drives: E46 M3
I see. So does that mean if the shocks are changed we lose the comfort, sports and sports + settings?
Sorry I think I'm confused between EDC vs Adaptive suspension...
      06-11-2015, 10:46 PM   #6
pikcachu
pikcachu's Avatar
1399
No, you only lose the EDC part.... you still get comfort, sport, sport+ for steering, throttle, transmission
they are pretty much the same thing... adaptive suspension includes... suspension that adapts to the road, so if rough road it will adapt the dampening so it's more comfortable but at the same time it will make dampening stiffer when you go to sport
      06-11-2015, 11:33 PM   #7
Mjosh
Drives: E46 M3
Got it. Appreciate you explaining the details!
      06-15-2015, 06:50 PM   #8
cbbplanet
28
Drives: space shuttle
Just know once you delete edc, you can't go back to stock. You have to cut and splice wires. Only way of going back is to splice back the module but that is visible (for those worried about warranty)
      07-05-2015, 09:58 PM   #9
hoppy6698
hoppy6698's Avatar
Drives: M235i, Estoril Blue on Black
Pikachu - do you know the coding lines to do this at home through the software, or does this require something above and beyond?
If we get a suspension without DDC (Like KW V3 DDC), is the module just coded out or does the wiring get modified (cut/capped/etc) and it still needs coding?
I want to move to something like Bilstein B14 or B16 coils, but don't want the car to end up in limp (comfort) mode permanently.
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
      07-05-2015, 10:08 PM   #10
pikcachu
pikcachu's Avatar
1399
I don't... I have seen it advertised in a few places but seems like the coding is not publicly available or it is more of a flash than coding....
      07-05-2015, 10:40 PM   #11
Alpine F31
Alpine F31's Avatar
Drives: MB E350 4MATIC Estate
He did mine.
2addicts
