Nail in my run flat!
02-15-2008, 02:03 PM | #1 |
123
Rep 1,675
My low tire pressure light came on so i went to the dealer to get it checked out. While inspecting the right front tire there was a nail close to the middle. BMW's asking $460 for tire and labor. Since it was pricy I decided to fill it back up with air and drive it for awhile. lol Air is leaking out slowly but the car is still driveable. Can it be patched?? or am i gonna need to order a new tire soon??? I'll post pics up when i get home from work.
[SIGPIC]2015-Cayman S (Can't leave bimmerpost)
2009-E92 M3 2005-E46 M3 1998-E36 M3 2007-E92 328i[/SIGPIC] |
02-15-2008, 02:05 PM | #2 |
Rep 7,433
you dont really want to patch a RFT. you can get a replacement on tirerack and just have someone install it for a lot less than the dealer will do.
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
02-15-2008, 02:06 PM | #3 |
76
Rep 1,883
I've heard of people patching these, although it probably isn't recommended. You can probably get the same tire for a lot cheaper from tirerack.com. This is why I got the $500 tire insurance, I'm getting a tire replaced today and I had 3 tires replaced on my previous 335.
02-15-2008, 02:06 PM | #4 |
123
Rep 1,675
is there any risks in fixing a run flat??
02-15-2008, 02:07 PM | #5 |
123
Rep 1,675
the replacement plan is like $700 here little pricy
02-15-2008, 02:09 PM | #6 |
322
Rep 17,316
Drives: E92 M3, E30 325i
i dont think they offer any tire insurance plans in california.
02-15-2008, 02:11 PM | #7 |
Rep 7,433
risks are that the patch wont hold and will tear again. depending on what tire it is, it can throw off your alignment and make your call pull. the light will come on again probably and you'd probably want to dsc and dtc on and not take things fast anymore because its easier to blow out a compromised tire
-Brian
02-15-2008, 02:25 PM | #8 |
Longhorn Fanatic
Rep 52
Got the tire warranty with the purcgase of my 2006 e90 and have had 8 tires replaced due to damage... Just had both backs replaced yesterday due to nails...
02-15-2008, 05:26 PM | #9 |
Rep 16
You can have a runflat repaired if its not a performance tire and if hasn"t damaged the sidewall. Firestone has plugged two of my Bridgestones on my non-sport sedan. I got another alarm today. One tire is about 3 psi low so I"ll pump it and see what it does.
02-15-2008, 06:13 PM | #10 |
Rep 61
Yes, you can patch them as long as is not too close to the side wall.
America's Tire has patched two of my runflats. And if you want to pay less don't go to the dealer. One of my runflats could not be fixed and the dealer wanted $80 more. |
02-15-2008, 06:22 PM | #11 |
Rep 561
Guys it's not a big deal. A patch installed from the inside of the tire is the best option other than a replacement.
Sure you can plug it from the outside but I wouldn't drive high speeds for extended time. The downside? mose tire shops charge extra to remove and reinstall a runflat tire due to stiffer sidewalls.
-Chris
2007 Montego Blue 328xi Sedan | Poplar trim | Steptronic | Cold Package | Power front seats w/memory | Xenon Adaptive Headlights | PDC | 2008 Plate LED's | PBX | LUX v5.2 |
02-15-2008, 08:52 PM | #13 |
Rep 151
I had a flat on a non-RFt and I had the tire pulled off of the rim. The shop put a plug in it and a patch on it. I drove that tire for 20000+ miles without issue. I have read where some shops won't patch a RFT and others will. I wonder if there is an increased level of difficulty in removing a RFT from the rim? After all, the tread, but not the sidewall, should be the same on a RFT and non-RFT so I don't see any reason why you can't fix one.
02-15-2008, 10:50 PM | #14 |
78
Rep 2,287
02-15-2008, 11:11 PM | #15 |
13
Rep 351
Drives: 2007 E90 335i
I had a nail in my tire 3-4 weeks ago, but because I have tire warranty, so i replaced it totally. I don't think you can patch though. And with RFT's, you can drive for another 100 miles.
2007 E90 335i|6MT|Sapphire Black Metallic|Black Leather|Aluminum Trim|ZSP|ZPP|CWP|Aluminum Pedals|M-Aero Kit|Blackline Tailights|E46 ZHP Knob|Euro Foglight Switch|M-Sport Perforated Leather steering wheel|M-Sport Perforated E-Brake|Front Carbon Fibre Splitter Kit|BMW Performance 19" Wheels|Meisterschaft Touring Exhaust Full Cat-Back System
02-16-2008, 12:00 AM | #16 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
Just patched my RFT Continental today. No problem. I put it to 120 for 45 sec straight, then took a curb at 70mph with no problem. Feels the same. As long as you don't get another nail or flat in that same tire, your tire will be good. I though the same thing you did, should I go to dealer. Mines was a bolt, not a nail, three times thicker than yours and it patched up just fine. Don't put a plug as high speeds or heavy loads will likely leak again through the hole. If it's your sidewall, then the tire is no good. That's the whole reason you have a RFT, the sidewalls. Order a new tire from tirerack or a discount tire store and install it yourself at a local tire shop. Patch it from the inside, then re-balance the wheel. Save your money and then replace both rear or fronts when treads are showing their age.
02-16-2008, 03:11 AM | #17 |
Rep 629
i have it from brecht bmw here in san diego......about $700 if i remember correctly.
SG e90 | Black Dakota Leather | ZPP | ZSP | 19" BBS LM Reps | Steptronic
iDrive | Aluminum Trim | Xenon | CF Roundels | 15% Tint |
02-16-2008, 11:10 AM | #18 |
18
Rep 304
Drives: 2007 black sapphire coupe JB+
I bought this insurance for my tires for $700 when I bought my car. So whenever I get a puncture I just take it in and they throw a new one on there.
02-16-2008, 11:31 AM | #19 | |
Absolute0
168
Rep 5,078
To procede or not to procede......
02-16-2008, 02:41 PM | #20 | |
waiting for diesel to reach the US
Rep 26
02-17-2008, 12:08 AM | #22 | |
Rep 613
