List your 6AT Mods for Road Racing / HPDE
07-02-2015, 02:25 PM | #1 |
Boost
1354
Rep 3,692
Drives: 135i M-Sport
I am just now getting hooked on road racing as I've really only Auto-x'ed in the past and my car is my DD.
I did a pretty good job preparing my car for the track (I think) and didn't see any limps my first time out at Buttonwillow in 100* temps. Mods below: Dinan FMIC Dinan Oil Cooler Mishimoto 9 row AN10 Transmission Cooler 50/50 - Coolant/Distilled + 24oz Watter Wetter Redstuff Pads Motul RBF 600 JB4 + MHD Flash - 15psi/12:1AFR/12deg max timing E40 fuel + Meth/Water cooling VRSF DPs Mfactory LSD Koni Yellow + Dinan Springs Dinan F&R Sways PSS tires (got greasy 15min into sessions) Up next: - Better brake ducting - Rebuild Tranny cooler mounting to help with airflow to brakes - KW Coilovers w/ swift springs - Up for suggestions
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
07-02-2015, 03:28 PM | #2 |
Boost
1354
Rep 3,692
Unfortunately, as you can see, due to hose kink issues I had to mount my tranny cooler in front of my oil cooler, my oil Temps didn't get above 255* so I'm not super concerned but it blocks my brake ducting on the passenger side.
Not sure how efficient our brake ducting is but my brakes did get a bit soft near the end of some runs due to slow traffic. What a horrible addiction I now have lol |
07-02-2015, 04:00 PM | #3 |
Rep 3,251
The more you mod the car beyond its stock configuration, the more potentials for problems developing at the track, as you have already found out.
Not sure why you bother with messing around with trans cooler, while still running on street orientated tires like PSS and pads like EBC Red, which won't hold up at all at track once you start driving the car to its full ability. If you are new to DE/track driving, I would just invest in some proper track capable street tires (Bridgestone RE11, Hankook R-S3, etc.)and real track pads and focus on your driving instead. Ditch the meth injection, they are not reliable for road course uses and they are known to fail and cause hydrolocked engine. And there is not much point of running meth if you have E85. Also, should have done the rear subframe bushings while you had the rear sway and lsd installed. Flash the TCU to the Alpina software as well if you haven't done it already.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
07-02-2015, 04:53 PM | #4 | |
Boost
1354
Rep 3,692
This is a daily driver that will see 10-12 track days a year. I plan to pick up some RE-11s but I have a 75% new set of PSS on the car now... the PSS got quite greasy and picked up a lot of rubber by the end of the day but no chunking... I could definitely use some camber plates and m3 arms. I didn't time my laps but I was pushing it and keeping up with much more powerful cars in the "intermediate" group. The meth/water is fine as I'm just using it for cooling, not for octane which won't result in any sort of catastrophic failure. As far as brakes go, the bite was pretty decent with the redstuff pads, again they're like 6 months old so I'm not going to swap them out until I need to - suggestions on a good streetable track pad? I don't understand your argument regarding the tranny cooler, it's a reassurance that the tranny will stay alive during a 30min+ session - the temp at all tracks near me is ~100* throughout the summer and I plan to keep the car for a while. I know you suggest the CSF radiator over a tranny cooler but my coolant temps didn't break 205* in ~100* heat. Obviously I'll see more weaknesses crop up as I start pushing the car harder but the tranny cooler took me 3hr to install and was only ~$200 w/ hoses, core & fittings.
07-02-2015, 04:56 PM | #5 |
Boost
1354
Rep 3,692
BTW, how are the TCKline coilovers?
Looking back, I was mistaken... my coolant did get up towards 215*
07-03-2015, 12:05 PM | #6 |
Rep 3,251
- You need to pay attention to the line pressure with the addition of trans cooler. It has been documented an in-line cooler result in significant drop in line pressure. Not a good thing considering everything is hydraulic actuated. That's the biggest reason why I think adding a trans cooler on these cars is a terrible idea, unless you have data showing that you are still able to retain the same line pressure.
- PFC 08. Only pads that can stand the abuse I put through on this car. Noisy on the streets, but still work just fine in cold temp. The fact EBC Redstuff works for you means you are either not driving the car very fast or the track is very very easy on the brakes. I tried Yellowstuff, which is more aggressive the Redstuff, on my car last year. They literally fell apart once I picked up the pace. - I have TC K DA. They works well, but for +$3k new, there are better options out there if you can just stretch the budget a bit more.
07-03-2015, 12:17 PM | #7 | |
Boost
1354
Rep 3,692
I agree with you on line pressure being a concern, I actually considered putting a sensor in there since I have it spliced to measure stock and then measure again with the cooler installed. This is something I plan on doing in the next few weeks, thankfully there are several people who have run a large core than me (likely more pressure drop) for years without issue. I will post my results once I do some testing. How often do you get out on the track? I'm considering the bilstein pss9 now, I have had some expensive builds and I'm really trying to keep this one under $5k hence me trying to cheap out on coils (KW ST/v1) but I know I'll want to upgrade as soon as I install them.
07-03-2015, 12:41 PM | #8 | |
Rep 3,251
Whatever coils/shocks you go with, a set of camber plates would be necessary if you don't want to wear our your tire shoulders prematurely. Never had Bilstein before, so can't comment. But look for a kit that offers high spring rates (+400lb/in front, +700lb/in rear) and have shocks that can properly damp those spring rates. Customer service and rebuild-ability of the kit is important as well, if you plan on keep the car for the long term. I heard Bilstein is pretty bad on that part. I would personally go for a set of single adjustable Motion Control Suspension coilovers paired with Vorshlag plates if I have to do this again. I honestly think these TC K and Ground Control stuff are just glorified Koni shocks, but I know some might disagree with that. For this car and for the purpose that you are building toward, I would spend majority of your budge on the suspension components, considering how heavy the chassis is and how fast it can be on the track. You might want to ditch your rear Dinan sway depending your driving style. My guess if that anything stiffer than the stock ZSP rear sway will be taking away too much traction from the rear.
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization Last edited by Cloud9blue; 07-03-2015 at 12:47 PM.. |
07-03-2015, 01:58 PM | #9 | ||
Boost
1354
Rep 3,692
Thanks for the suggestions!
07-06-2015, 11:07 PM | #10 |
1008
Rep 1,563
My setup on my X1 35i Msport
Stoptech ST60 BBK JRZ RS Two coilovers Swift Springs 11k/16k Pure Turbo Stage 1 upgrade PFC 11 brake pads CSF Racing Aluminum Radiator Turn In Concepts custom dual core oil cooler Wavetrac LSD JB4 with flexfuel wires ER chargepipe ER Intercooler BMS downpipe NGK plugs M3 rear sway bar M3 rear subframe bushings M3 rear guide rods Ground Control Hybrid camber plates Kartboy rear end links Alpina B3 transmission flash Fuel-it stage 2 lpfp 275/40/17 square Nitto NT01 on apex arc 8 wheels Next step is ducting for the oil cooler and cutting out the midcats (which I suspect are clogged) and replacing with vibrant resonators. |
07-07-2015, 12:42 PM | #11 | |
Boost
1354
Rep 3,692
I went with the bilstein pss9 because I found them cheap second hand low miles and rebuilding the struts is only $190/ea, the springs are 385/615 which should be sufficient.
07-07-2015, 05:19 PM | #12 | |
1008
Rep 1,563
07-07-2015, 06:52 PM | #13 | ||
Boost
1354
Rep 3,692
07-22-2015, 04:13 PM | #14 | |
Boost
1354
Rep 3,692
07-22-2015, 05:03 PM | #15 |
California-bound
385
Rep 1,480
For reference, what were your lap times? I didn't have issues until I started going faster. Buttonwillow is a bit easier on these cars in terms of temps because of all the straight away space to ram air through the rad.
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
07-22-2015, 09:58 PM | #16 | |
Boost
1354
Rep 3,692
Which apps do you guys suggest for lap timing?
07-23-2015, 09:57 AM | #17 |
Rep 3,856
I would add camber plates to gain some negative camber
07-23-2015, 10:51 AM | #18 | |
Boost
1354
Rep 3,692
07-24-2015, 01:22 PM | #19 |
Rep 534
Harrys lap timer is what I use and it works really well.
07-24-2015, 03:03 PM | #20 |
Boost
1354
Rep 3,692
FYI Amazon is great, they honored EBCs warranty and gave me a full refund on my redstuff pads. Putting on Stoptech 309s to see how they do for steet/track duty and if they don't hold up at the track I'll pick up some PFC pads for the track and swap to the stoptechs for the street.
07-25-2015, 12:02 AM | #21 | |
Rep 3,251
once you overheat them, you most likely won't want for street use either since they won't bit nearly as well as before and often generate excessive brake squeals due to uneven wear. just get some real track pads...
07-25-2015, 12:34 AM | #22 | |
Boost
1354
Rep 3,692
