2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes M235i H&R sway bars with Ground Control adjustable front endlinks
      07-31-2015, 02:41 PM   #1
Liquidpaper
Liquidpaper's Avatar
Drives: '15 M235i
2015 BMW M235i  [0.00]
Getting them installed Monday. Might take some time -- it's a pretty intensive process for F-Chassis BMWs. I'll post a review once I get it done.
      07-31-2015, 05:38 PM   #2
Iceman51sn
Drives: 2015 AY M4
Fantastic! Very much looking forward to your review. I'm curious as to the quality of the endlinks?
      07-31-2015, 06:05 PM   #3
ketema
Drives: 2015 M235i
I've got my car in the shop getting my hotchkis bars installed. What do end links do and/or improve?
2015 6M Black Sapphire Metallic | MPE w/Carbon Tips | Digital MP Steering Wheel | Carbon Interior | StopTech Slotted Rotors | Pagid RSL1 Race Pads | KW Clubsport Coilovers | DINAN Stage 2 and Carbon air intake | Clutch Masters Lightweight Performance Clutch and Flywheel | Hotchkis Anti-Roll Bars | Enkei RS05RR 18" Racing Wheels
      07-31-2015, 06:43 PM   #4
Liquidpaper
Drives: '15 M235i
They do a few things. They allow you to retain the stock geometry of the bar when your car is lowered, and they allow corner balancing on the front -- you can adjust the front links to add or remove pre-load on the front bar.
I didn't even know Hotchkis had bars out for the M235i yet.
      07-31-2015, 07:14 PM   #5
ketema
Drives: 2015 M235i
Cool. I pinged Donovan to get pricing.
Pretty sure I'm the first person to get the Hotchkis production bars. I badgered them almost daily lol.
      07-31-2015, 07:46 PM   #6
x233
Ukraine
284
Drives: M2C, M235xi
You can change the sway preload with them, therefore, change the balance of the car (make it more or less prone to understeer), and limit weight transfer in a corner or when changing directions sharply (make it more or less stable and responsive).
Typically, if you make the front end links shorter the front end will be stiffer, therefore, more prone to understeer mid-corner but will be more responsive (sharper initial turn in) and more stable on a straight but less comfortable on less than perfect roads.
If you make them longer (effectively makes the arm of the sway bar longer) the front end will be softer and less prone to understeer mid-corner (to the point of outright oversteer depending on your settings) but slightly less responsive (slushy initial turn in) and less stable on a straight but generally more comfortable.
Appreciate 3
      07-31-2015, 11:22 PM   #7
Dan GSR
Drives: GTI
dinan says its a 6 hour job
      08-03-2015, 12:06 AM   #8
Liquidpaper
Drives: '15 M235i
Goods before install.
      08-05-2015, 01:43 PM   #9
Pparana
Drives: 2015 m235i
those links look way too long, could be wrong, but I am not sure you will be able to get the bar parallel.
      08-06-2015, 10:21 AM   #10
Liquidpaper
Drives: '15 M235i
Just got my car back last night. The endlinks are the right size, but the hardware on the ends needs to be swapped, so I'm using the stock endlinks right now. They do just fine for a modest (1 inch) drop. I think if you were slammed on coilovers or something, you might need them more.
Survey says -- awesome upgrade. A gigantic pain in the ass to get the sway bars installed (very expensive if you aren't doing it yourself), but definitely stiffens the car up and kills any body roll the car might have had.
      08-06-2015, 06:08 PM   #11
ocN55
ocN55's Avatar
Drives: '15 M235i 6MT/ '16 M3
Did the front and rear sway bars require dropping that subframe? Sounds like a really involved install from what I'm reading.
FBO M235i r
F80 M3
      08-06-2015, 06:23 PM   #12
Liquidpaper
Drives: '15 M235i
Yes, installing both the front and rear sway bars requires dropping the front and rear subframes. The rear isn't that bad, but the front basically requires you to disconnect the motor-mounts, brace the engine, and drop the subframe to get at the sway bars.
To be honest, although I like the upgrade, if I wasn't tracking the car, I wouldn't bother. It's too much of a hassle.
      08-07-2015, 07:04 PM   #13
Pparana
Drives: 2015 m235i
I have had the sways on my car since February, the stock links will interfere with the steering under deflection. Uuc makes a end link kit if that set does not work out, you need the bar parallel to the ground with no preload.
I will post a picture of what the stock end links looked like after a track day running hr springs and camber plates when I get to my shop and can dig them out, absolutely destroyed them.
      08-07-2015, 11:08 PM   #14
ketema
Drives: 2015 M235i
Can the end links be installed after sways without re dropping the subframe?
Post pics of the damaged stock one please.
      08-07-2015, 11:10 PM   #15
ketema
Drives: 2015 M235i
Damn. Another part from GC that needed adjustment after the fact? I actually ordered a pair, but they didn't get shipped out in time and then the seats were already in so I canceled. Hearing this I'm glad I didn't get them.
      08-08-2015, 10:09 AM   #16
Pparana
Drives: 2015 m235i
Yeah they just bolt to the shock and the bar, could be done on a jackstand. Sway bar connection is done with the car on the ground.
      08-08-2015, 10:17 AM   #17
Pparana
Drives: 2015 m235i
Also I replaced the rear ones, there plastic from the factory. The factory rear sway bar was about as thick as a pencil, not sure if the plastic ones would bend too much. For a 150 bucks seemed reasonable.
      08-08-2015, 10:28 PM   #18
i8ur911
125
Drives: F22 228i MSport
Interested in seeing pics of this. I have H&R springs and sways with F8x LCA's....so far end links are good after multiple autocrosses....no track days with sways yet though.
      08-16-2015, 10:29 PM   #19
Pparana
Drives: 2015 m235i
Here are the Picts, they also make the bar hit the tie rod ends under certain conditions, may not be an issue w the 228 since it is lighter. If you look at your bar and it is chipped up, then you know it's hitting.
Kind of hard to tell from photos but drivers side is a little bent.
      08-16-2015, 10:30 PM   #20
Pparana
Drives: 2015 m235i
More photos, iPad wan me to do one at a time
      08-16-2015, 10:31 PM   #21
Pparana
Drives: 2015 m235i
And one more
      08-20-2015, 09:43 PM   #22
i8ur911
125
Very interesting......I'm gonna have to check out my links now. Thanks Pparana!
2addicts
