08-03-2015, 03:27 AM | #1 |
Rep 17
Is adaptive led headlight fully enabled in canada ?
Hi everyone !
I'm picking up my m4 in August. Just curious if the adaptive led equipped on Canadian cars fully enable with beam split and etc functions or is it like the USA spec car with only high-beam assistance enabled. Thank you |
08-03-2015, 08:57 AM | #2 |
Rep 2,524
it will be the same as US Spec. I've been reading the coding discussions and it seems like it's still ambiguous what combo of options you need in order to have the necessary hardware to activate via coding.
08-03-2015, 09:01 AM | #3 |
Rep 17
Thank you for the respond.
I was going through a similar thread in the general function and found out that it needs to be coded. Now more thing to worry about before my car arrives haha. |
08-12-2015, 02:23 PM | #5 | |
21115
Rep 20,741
Drives: 2021 911 turbo
However, as alvinsl posted, you will need the Tech Package, if only for the stupid little button on the turn signal stalk. Since I have Speed Limit Info, I have the required camera. But since I don't have the stupid little button, I cannot code the ADHL .
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
08-12-2015, 09:32 PM | #6 | |
Advocatus Douchebagus. Sex Marxist.
2415
Rep 3,415
Drives: Lucy.
Drivin' Lucy
08-13-2015, 06:12 AM | #7 | |
21115
Rep 20,741
http://f80.bimmerpost.com/forums/sho...&postcount=317
08-13-2015, 02:27 PM | #8 | |
365
Rep 362
I didn't check the tech pack option, so I can't test this for myself. |
Tags |
active led, beam shaping |
