2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Oil change
      08-16-2015, 04:40 PM   #1
grc
Drives: M235i
Oil change
I am planning to do an oil change for my M235i. How much oil should I plan to buy? I read 7qt somewhere.
Btw, this is my first car without a dipstick so once I start adding oil after I drain the old oil out, when do I know I have added enough? Is the only way to get in the car, start the engine and wait for the electronic dipstick to perform a check?
      08-16-2015, 05:05 PM   #2
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
You need 7
      08-16-2015, 05:21 PM   #3
M-terkait
M-terkait's Avatar
Kuwait
209
Drives: F30 335i 3/13
6.5L
Docrace 6266
      08-16-2015, 06:48 PM   #4
pikcachu
pikcachu's Avatar
1399
filter takes another 0.5
      08-17-2015, 04:07 PM   #5
Zooks527
Drives: 2015 M235xi / 2005 Tacoma 4x4
The BMW branded oil is now sold in liter bottles. Buy 7 liters, put 6 in, get the engine warm and check the level. Odds on, you'll find it reads at Max.
The sump is 7 quarts. There's some holdup when you drain it, especially if you do it on ramps, and 6 liters will usually do just fine. Put the leftover liter in the trunk.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/BimmerTech amp, Enhanced BT
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi
      08-17-2015, 05:00 PM   #6
grc
Drives: M235i
Thanks for your suggestion, that is what I was thinking too.
Having no dipstick is just weird. I am coming from an Audi S4 that also had an electronic dipstick, but there was an actual dipstic slot in the engine and you could buy a dipstick for $15 and plug it in. I am surprised that this is not an option for the Bmw
      01-31-2016, 08:04 PM   #7
Robimplicit
Drives: M2; 335d
So, if using ramps on the front end, not all oil drains? If so, seems it would be better to use jack stands to get under car to open drain plug, remove jack stands and drain for 30 minutes more, and jack up again and install drain plug. Extra work but maybe worth it to get old oil out completely. Are there standard locations for jack stands on each of the front corners?
Thanks.
      01-31-2016, 08:16 PM   #8
overcoil
Drives: M235i 6spd
Thanks.
Thats what I do without the jack stands, jack it up then once plug is out and drain pan positioned lower floor jack. Dangerous and stupid, but I use an old wheel as a safety barrier.
      01-31-2016, 08:48 PM   #9
pikcachu
pikcachu's Avatar
1399
Thanks.
Best is to use the ramp opposite of the garage slope for example.... so the result would be almost flat....
else when the oil starts to drip it will start falling onto the cover liner...
      01-31-2016, 11:12 PM   #10
overcoil
Drives: M235i 6spd
Your right, that why this is a good tool
http://formafunnel.com/
      02-01-2016, 03:26 AM   #11
Zooks527
Thanks.
Honestly, I don't worry about the half quart of holdup. I'm changing at twice the stated frequency that BMW specifies and with the break-in change and then an early change, the first BMW "free" change was the third time the car's oil was changed. At that rate, I don't really worry about getting "only" 93% of the old oil out when I do it.
2addicts
