Michelin PSS tire pressures for lapping day
08-18-2015, 02:40 PM | #1 |
Rep 126
What tire pressures do you recommend for an E90 335i xDrive with Michelin Pilot Super Sports stock staggered sizes (225/40-18 front / 255/35-18 rear)?
And since I'm asking... what pressures are recommend on the street with those same tires? The factory 36F/41R (cold) pressures seem way too high. Last track day my rear pressures shot up to 48 after just a few laps. I then dropped them to 36F/36R (hot). Thanks! |
08-18-2015, 05:42 PM | #2 |
Rep 670
You could drop the rears to 38 cold and see how that treats you. Try a bit lower on the front but watch for sidewall roll. I find 34ish cold to be about the lower limit for the street for the fronts. 36/38 hot on the track sounds about right to me. I run PSS street and track too. Same sizes.
08-20-2015, 03:00 PM | #3 |
Rep 3,856
From my experience and some others at road courses, we'd normally run them at 36-37 hot
08-20-2015, 04:00 PM | #4 |
BimmerPost Supporting Vendor
1423
Rep 2,657
You certainly want to drop pressures once arriving to the track. How low (your baseline) will be determined by the temperature of the track (conditions) and your driving style. On a hot day, your temps will rise a bit higher/quicker. On a cooler day, temps will not rise quite as fast. Keep a log, and this way you will have historical data for the future. This should help with determining your baseline when you first arrive to the track.
Furthermore, I would think about purchasing some extreme summer tires (depending on how often you take the car to the track). Although the MPSS are fantastic street tires in respect to wet and dry performance, they do not hold up under track conditions and repetitive lapping. The heat will start to deteriorate the tires, and you will find yourself spending more money in the long run managing these street tires for double duty use. I recommend going to an extreme summer tire like the Hankook RS-3, Dunlop Direzza ZII Star Spec, BFG Rival, or Yokohama AD08-R. All of these can be daily driven in reasonable climates, and certainly driven to and from the track. Most of these perform best anywhere between 36 - 38 hot, but it is difficult to make a blanket statement as everyone has their own personal preferences. - Ryan
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
09-01-2015, 07:48 AM | #6 | |
Rep 3,856
09-03-2015, 09:54 AM | #8 | |
Rep 670
2010 335i e90 Le Mans Blue/Chestnut Brown | M-Sport | 6MT
09-05-2015, 04:38 PM | #9 | |
2280
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.20] |
It's going to royally suck when you come back to the pits only to find your PSS all shredded up. I use PSS on cold / wet track days and even then I find Star Specs can handle damp conditions quite well. |
09-14-2015, 10:56 PM | #10 | |
Rep 93
Drives: x
update
So, the above quote by me. For whatever reason, I had thought when I was at ThunderHill (this June), that I had been at 25 previously (Oct of 2015). So I ran at 25 the last time there (June)--it was super hot and the car actually felt pretty good. After reading through some of your comments, I thought, wow, I'm really an outlier here. So I read through my earlier notes from last fall, and found that I had been at 35 last fall, not 25. Going from memory on this may not have been a good idea... Today I did a track day at Sonoam and the On Edge guys had me at 39 fr and 42 rear after a few rounds of adjustment (on a fairly cold day). Car never felt great all day, though I'm not sure that was the tires. |
