335d LED angel eye bulbs
08-27-2015, 01:48 PM | #1 |
Rep 700
Forgot I had some in my garage... They've been sitting since 2012! Lol
Anyway I was poking around and attempted to remove one of the factory bulbs and was pretty surprised at how much of a PITA it is to change this particular bulb on a 335d! Not sure if it's the same for all E90 chassis. Anyone else that has changed their angel eye bulbs feel that the wiring for the plug to the bulb is unnecessarily short! Does anyone have tips for making this job easier? |
08-27-2015, 02:01 PM | #2 | |
Rep 1,442
08-27-2015, 03:08 PM | #3 | |
Rep 56
It took us about an hour total with both of us trying to get the new bulbs in. We eventually got it done. It's not that it's a hard job to do, it just takes patience. And small hands is an advantage Take your time, the results are worth it. |
08-27-2015, 05:14 PM | #4 | |
Rep 1,442
08-27-2015, 05:24 PM | #5 |
Rep 700
Everything fits inside the headlight housing? These bulbs have something else that plugs into them before the vehicle harness is plugged into it. I don't want to leave the caps off the headlight assembly.
08-27-2015, 05:37 PM | #6 |
Rep 1,442
You will be amazed that you can fit everything back into the headlight housing and reseal it. As you will see in the angel eye instruction booklet you will need to remove a plastic stub inside that housing assembly. Once that is done everything including the bulky plug/transformer can fit inside the housing so that you can screw the rear cap back on.
08-27-2015, 07:04 PM | #7 | |
Rep 700
08-27-2015, 10:00 PM | #8 |
DIESEL POWER
13
Rep 80
Drives: 2011 E90 335d
I highly suggest taking off the top plates, couple phillips screws, under the weather seal. This cover will give you an essential point of view for lining up bulbs and untangling wires if they are caught. Mine were hung up on the little metal pieces inside the housing.
08-27-2015, 10:23 PM | #9 |
Rep 73
Drives: 2011 335d
What bulb/kits have you guys used? I would hate to have to do it more,than once for a while. Are they the white LED bulbs? They will look awesome on my Alpine '11
2011 335d:Mostly stock for now
2007 BMW K1200s: PCIII |
08-27-2015, 11:29 PM | #10 |
DIESEL POWER
13
Rep 80
I got these cheap ones to see how I would like it. http://www.ebay.com/itm/281703234741
They are better than the stock ones, but not that bright. Can't really see during the day. I also turned up the voltage to the angel eyes on Carly, which helped, but I may swap them out for brighter ones.
08-28-2015, 01:00 AM | #11 | |
Rep 1,442
08-28-2015, 04:59 AM | #12 |
Rep 2,383
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
08-28-2015, 08:25 AM | #13 | |
Rep 56
They definitely give a more updated look to the 335. |
08-28-2015, 01:50 PM | #15 | |
Rep 28
https://www.e92-lighting.com/bmw-led...eyes-v10-128w/ Will report back once installed |
08-29-2015, 10:00 PM | #16 |
Rep 1,442
08-29-2015, 10:48 PM | #17 | |
Rep 700
08-30-2015, 09:54 PM | #18 |
Rep 129
I have the RGB ones from e92 lighting. Rice, I know. They stay white on the road, but when I park, the blue matches the paint nicely.
08-31-2015, 12:24 AM | #19 | |
Rep 87
thanks! |
08-31-2015, 06:24 AM | #20 |
Rep 3,489
Drives: Montego Blue 335d
I buy my bulbs thru bimmian.com they're coming in LED now with a LIFETIME warranty expensive though. I got my Fog lights in LEDs from them and the Angel eyes in RED from them also
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
08-31-2015, 10:47 AM | #22 | |
Rep 56
I just installed some "whiter" halogen foglight bulbs. To do this, I had to remove the inner wheel liner. Low and behold there was the housing for the angel eye bulb in plain sight and easy reach lol. If I would have known this, I would have removed the wheel liner to gain easy access to the angel eye bulb. The added work of removing the wheel and wheel liner would have been worth it, probably reducing installation time and definitely reducing frustration |
