09-07-2015, 01:23 PM | #1 |
1L
156
Rep 336
1st Oil Change Issue
Bought my oil change kit from getBMWparts and as I was pouring the first three liters, my son noticed a different type of oil on the other four. It was 5W30, Longlife-01/gasoline/diesel that I first poured. The other four is 5W30, Longlife-04/Diesel. So I am stuck at this point because I do not have the right ones. I wished I had noticed this first thing before removing the old oil.
Does anyone have any recommendation for me? If "getBMWparts" was available when I called them, I would have some answer. Do you think it will be safe to use the "04/Diesel"? Any suggestions is greatly appreciated! Thanks!
2015 Glacier Silver M235i/6MT
MP Front Splitter//MP CF Short Shifter//MP CF E-brake//MP LSD//Cold Weather package//Driver Assistance package//Oyster Dakota leather//Aluminum Hexagon trim//ECS Tuning Wheel Spacers//AutoPlus Rear Diffuser//HUD//Rexing DashCam//AutoID M Mirror Caps |
09-07-2015, 02:03 PM | #2 |
Rep 5,577
1Legit, I'm not at my home where I have the BMW branded oil bottles of both the Castrol and the new updated Shell oil for our 235. When I get home later I can view the bottles and snap a picture so you know what the bottles Frm the dealership look like.
Believe the part # should be 83212365946, but I need to double check. |
09-07-2015, 02:14 PM | #3 | |
1L
156
Rep 336
09-07-2015, 02:35 PM | #4 |
Rep 5,577
I would go to the Shell Pennzoil web site and use their OIL SELECTOR to find an oil.
Or the Castrol site and their OIL SELECTOR. http://lubematch.pennzoil.com/recomm...e=18&brand=121 Last edited by overcoil; 09-07-2015 at 02:44 PM.. |
09-08-2015, 05:50 PM | #6 |
Rep 86
Drives: '14 228i MSport
i used 0w40 European blend on my Subaru. but here ive used 0w40 European blend by mobile 1
09-08-2015, 09:05 PM | #7 |
Rep 228
09-08-2015, 09:07 PM | #8 |
Rep 957
09-11-2015, 02:12 PM | #9 |
Rep 228
09-11-2015, 06:16 PM | #10 |
Rep 957
If your wot alot (track), you will see a higher engine oil temp, 0W-40 will operate closer to design specs than 5-30. Feels the same, nothing noticeable. no fuel consumption change.
Also better suited for warm climates, so 5w30 for you. I grew up in Buffalo, so I know Toronto, you can run the 0w40 prob. 4-6 months a year if you wanted to. |
10-02-2015, 11:56 AM | #11 | |
Rep 1,026
LL-01 oil is a High SAPS oil, with higher TBN, so it protects longer. If you change your oil more frequently than say the suggested 10,000 mile interval, like at 5,000 miles, you should be okay. However, how quickly the TBN breaks down depends greatly on your driving habits. In your case, you could use it, but just need to leave this blend in for a shorter typical time period. |
jpnh1423.50 |
10-05-2015, 02:11 PM | #12 |
1L
156
Rep 336
Thanks Iron Man.
11-19-2015, 11:32 AM | #15 |
Rep 886
The sump is 6.5 liters / 6.9 quarts dry.
Buy 7 liters. Put 6 in at the time of the change. With residual holdup in the system, you should find the indicator at either 3/4 or Max after doing so. Put the 7th liter in the trunk.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/BimmerTech amp, Enhanced BT
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi |
11-30-2015, 07:42 PM | #16 |
Rep 228
Just did an oil change today. Mechanic says the 6 cyclinder takes about 6 litres. The N20 takes 5 litres. Just for info if you're changing your own oil.
Tags |
first oil change, oil type issue |
