What mileage did you tune / flash your car?
09-13-2015, 03:40 PM | #1 |
Rep 645
Hey all,
I've got around 95K miles on my N54 right now, and I'm still debating whether to flash it with MHD stage 1 93 (I know I know). The more cautious side of me says "leave it alone", as it's running perfectly right now and I don't really want any major repair bills, but I'm also curious about the extra power and know what the potential is. The engine runs well - when warm there is not a hint of lifter tick, it had new turbos at 60K, and a new waterpump at 85K. I've also done the belt, tensioner and every pulley. Plugs were also done around 10K ago. There are no leaks at present either and I always run it on 93. I guess the most important thing is it doesn't use any oil - at least not according to the e-dipstick. Between oil changes it never moves from the max reading on the guage. So by all accounts it should be fine but...here are my questions: What mileage did you tune at, and, when you did tune did your engine then begin to show signs of stress (other than coils)? Did it start to use oil? Was there anything that started to make you think you shouldn't have tuned? |
09-13-2015, 04:04 PM | #3 |
Rep 3,778
Drives: '11 328i '19 M6
Active Autowerke tune at 20K, now over 45K with no issues.
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
09-16-2015, 02:55 AM | #4 |
Rep 1,029
COBB AP V3 at 50,000 miles. Required a walnut blast, new injectors and plugs.
I blew the stock charge pipe apart at the throttle body and replaced it with an aluminum aftermarket charge pipe and BOV. While I had the stock air cleaner off, I decided to throw on BMW dual cone air cleaners - easier than reinstalling the stock air cleaner. You just have to realize that the increased performance comes with a price - accelerated wear and stress on parts.
"The likelihood of one individual being right increases in direct proportion to the intensity with which others attempt to prove him wrong."
2015 F82 M4 - Sakhir Orange Metallic 2013 E92 M3 / 2013 E92 335is / 2010 E90 335i / 2007 E90 335i |
09-16-2015, 03:10 AM | #5 |
7422
Rep 10,222
JB4 at about 90k, now at 100. Had walnut blast done prior to install.
Biggest issue was the internal DME failure. Which seems to me a somewhat common issue with the 07). Thankfully the fix isn't expensive. Agreed with the poster above, if you add boost, I would first get a charge pipe. My stock CP help up fine in map 1, however others have not been as lucky. |
09-16-2015, 06:49 AM | #6 |
Rep 554
Drives: 2013 335is E93 6MT
MHD Flasher at 19K. I had a 2008 335i with 95K miles, oddly enough, but I sold it in April. It needed a walnut blast, which I see isn't mentioned by the OP. I'd get that done first, although it appears to be the only thing you'd need to do at this point.
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
09-16-2015, 07:56 AM | #7 |
317
Rep 1,735
75k cobb ap v2, stage 2 FBO. im at 100k I had a valve cover leak may be due to high output of boost. No leaks after that, runs strong.
|instagram@underground6t9| |
09-16-2015, 09:24 AM | #8 | |
Rep 3,696
09-16-2015, 09:53 AM | #9 |
Rep 191
Only one (the OP) who mentioned turbo replacement so far. That's good. The last time I went to one of these threads, ~50% of the people seemed to have replaced their turbos before 100k. I'm sure many of those were due to wastegate rattle but certainly not all.
OP, you just got fresh turbos and that's the only $$$ item you should be concerned about. You're up to date on your maintenance, go have fun! |
09-16-2015, 03:48 PM | #10 |
Rep 645
Thanks all for your comments. I think the walnut blast and CP will be first on the list and then I should be good to go with the tune.
09-16-2015, 04:19 PM | #11 |
43
Rep 335
Just want to throw it in... My car broke pretty badly and unexpectedly after warranty. BMW covered most (but not all) of the cost at goodwill. But if you have tuned your car, I guess there wil be much less chance of any goodwil. So, there's something to think about even after warranty.
09-16-2015, 04:36 PM | #12 | |
Rep 645
09-16-2015, 09:58 PM | #13 |
432
Rep 1,602
I'd have to look at my spreadsheet, but JB4 on Map 5 at around 109k with a backend flash I did a couple thousand later. I had the tune on it just a couple weeks after purchase. I wouldn't have bought this car if I had to be stuck at near stock power levels...stock is lacking a bit.
