BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Help with aftermarket bluetooth/radio
      06-08-2005, 07:26 PM   #1
j505mni
Drives: 2006 325i Sedan
Hello people, I currently do not have BMW assist/Bluetooth and was told by the dealer that they can not install it after the fact. So long story short I purchsed a aftermarket bluetooth kit from Motorola. I have the base 325i with the base radio. The bluetooth kit has a radio mute wire for aftermarket radois and a external speaker. What I would live to do is hook the wire into the radio to trigger the AUX/Ipod input? if not atleast trigger the radio to mute and use the external speaker?
Thanks for any help, Jerry
http://motorola.digitalriver.com/ser...65700&Env=BASE
      06-09-2005, 01:43 AM   #2
Tierfreund
Tierfreund's Avatar
21
Drives: E90 330i
Well good luck.
You can not route the sound through aux-in because you cannot tell the radio to automatically switch to aux when a call comes. And thereīs no mute in on the radio because the factory phone systems send that info via CAN-BUS. There isnīt even an ignition lead on the radio (that you could cut with a relay when a call comes in), since the radio gets the info of ignition on/off via CAN-BUS as well. Next thought would be to cut the speaker wires with relays, but on 10 speakers, that would be quite a drag. So Iīd say: Time for a professional install (if you can find a real pro that wonīt chop up your E90 badly)
      06-09-2005, 10:43 AM   #3
SilvertE90
Drives: 2006 325i
2006 325i  [0.00]
Hmm thats interesting. Because the E46, E60 ect all have retro BMW bluetooth kits. They are about 300-400USD . I think the E90 is probally just not available yet.
      12-10-2005, 03:49 PM   #4
mishenka
Drives: 328i
j505mni,
Can you give an update on this issue? Were you able to do what you wanted? I am also interested in knowing if you like the quality/functionality of the Motorola bluetooth carkit that you bought.
Thanks,
mike
2008 328i, Black/Black, Steptronic
