09-20-2015, 10:51 AM | #1 |
114
Rep 336
M3/M4 lower control arms.
So I ordered these parts and will install them this week. Looks pretty straight forward. What I am wondering is if anyone else on the forum has installed them and what the results were? I have been through the threads but there is very little talk about the results forum members have had.
This is not a track car, just looking to get a little more camber up front. |
09-20-2015, 11:44 AM | #2 |
Rep 4,511
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
09-20-2015, 11:51 AM | #3 | |
Rep 5,262
http://www.2addicts.com/forums/showthread.php?t=1079766 |
09-20-2015, 01:58 PM | #4 |
114
Rep 336
Thanks Gents. I have read those threads a while back so it was nice to re-read them. Looks like it will add a few degree's of castor which I have no problem with and the camber gain looks perferct for the street. I have Xenons and will also install the M3/M4 bits for them as well.
09-20-2015, 02:40 PM | #5 | |
Rep 5,262
09-26-2015, 03:25 PM | #6 |
114
Rep 336
It's been 24 hours since the install and alignment and the car does feel better over all. I'm sure some is due to the alignment I spec'd and of course the control arms. Steering feel is pretty much the same maybe a tad stiffer. Turn in is where I notice it the most. Very immediate and more controlled. Worth the money especially since I won't shred tires in 13,xxx miles again.
Kikkomon4.50 |
09-26-2015, 07:48 PM | #8 |
Rep 5,262
09-27-2015, 05:50 AM | #9 |
114
Rep 336
I actually bought them from Turner Motorsports. They had them in stock. I wouldn't buy from GSR, they never returned my calls or emails when I was looking to purchase. Zero customer service.
09-27-2015, 08:00 PM | #10 |
125
Rep 356
09-28-2015, 11:14 PM | #11 |
Rep 2,363
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
Sorry if this is a noob-ish question but can someone explain the light leveling and what I would need for that? I am a bit confused.
Essentially it sounds like its the control arms and 2 other parts I would need. Can you break down what exactly I would need to make this work? Thanks!
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
09-28-2015, 11:30 PM | #12 | |
Rep 5,262
explanation of what you need with a picture of the final product is here http://www.2addicts.com/forums/showp...2&postcount=67 basically you reuse your stock leveling rod and just use one of the ball joints from the kit that comes with the arms |
09-29-2015, 07:42 AM | #13 |
114
Rep 336
You could save a little money if you just order the arm and use the longer ball end. There is no need for the bracket to relocate the sensor. You will have to adjust the lights but that is pretty simple. There is a link on here somewhere. Search is your friend.
10-08-2015, 08:30 PM | #14 |
Rep 138
any other tips for install ? I plan on putting them on tomorrow, haven't messed with suspension parts much.
also was my let's supposed to come with the leveling rods ? mine didn't come with any. I should be able to reuse the stock one right ? |
10-08-2015, 08:48 PM | #15 |
Rep 5,262
you need the ball ends else you won't be able to attach the rod
10-08-2015, 09:40 PM | #17 |
Rep 5,262
10-08-2015, 09:41 PM | #18 | |
Rep 138
10-08-2015, 09:45 PM | #19 |
Rep 5,262
depends if you bought the one for xenons or the regular one... the xenon one has the hole to attach the rod
http://www.turnermotorsport.com/p-21...trol-arms.aspx |
10-08-2015, 09:47 PM | #20 |
Rep 138
gsr is only selling one kit, and it comes with the lca with the hole on it for the rod, but it didn't come with the rod. guess I have to order my own. sucks, I wanted to put them on tomorrow
10-08-2015, 09:51 PM | #21 | |
Rep 5,262
you don't need the rod.... just the ball end with the bolt on the other side... so you pop out the stock ball end that comes with the clamp and put the ball end with the bolt.... I guess you could try to adapt the clamp to work with the M4 LCA but it won't look pretty This is how it looks with the stock rod and the M4 ball end |
10-12-2015, 08:30 PM | #22 | |
125
Rep 356
Again, just an FYI. |
