10-12-2015, 12:02 AM | #1 |
Rep 460
LED Tail Lights
Hi, I'm new to the whole 435i Gran Coupe world and I was wondering if there are any good sites that I can get performance parts such as LED bulbs to switch my rear brake and turn signals with?
Another question is that since the Gran Coupe is a 4 series coupe but 4 doors, will the same mods apply to both vehicles? I'm wondering because I don't see a lot of F36 mods components but plenty of F32 mods out there. |
10-12-2015, 03:03 AM | #2 |
Rep 69
Brake Lights: H21W HorizonLED 50W
Brake Lights Coding: REM / 3061 / BR_L_KALTUEBERWACHUNG from Aktiv to Nicht Aktiv REM / 3061 / BR_L_WARMUEBERWACHUNG from Aktiv to Nicht Aktiv REM / 3061 / BR_L_IS_LED from Nicht Aktiv to Aktiv REM / 3061 / BR_R_KALTUEBERWACHUNG from Aktiv to Nicht Aktiv REM / 3061 / BR_R_WARMUEBERWACHUNG from Aktiv to Nicht Aktiv REM / 3061 / BR_R_IS_LED from Nicht Aktiv to Aktiv Indicators: http://www.horizonleds.co.uk/cree-le...cree-led-bulbs Front turn signal coding: 3061 FRA_V_R_KALTUEBERWACHUNG -> nicht_aktiv : Disabling cold check for Front Right Turn Signal. 3061 FRA_V_R_WARMUEBERWACHUNG -> nicht_aktiv : Disabling warm check for Front Right Turn Signal. 3061 FRA_V_R_IS_LED -> aktiv : Setting Front Right Turn Signal type to LED. 3061 FRA_V_L_KALTUEBERWACHUNG -> nicht_aktiv : Disabling cold check for Front Left Turn Signal. 3061 FRA_V_L_WARMUEBERWACHUNG -> nicht_aktiv : Disabling warm check for Front LeftTurn Signal. 3061 FRA_V_L_IS_LED -> aktiv : Setting Front Left Turn Signal type to LED. Rear indicator signal coding: 3061 FRA_H_L_KALTUEBERWACHUNG -> nicht_aktiv : Disabling cold bulb checks for Rear Left Turn Signal. 3061 FRA_H_L_WARMUEBERWACHUNG -> nicht_aktiv : Disabling warm bulb checks for Rear Left Turn Signal. 3061 FRA_H_L_IS_LED -> aktiv : Setting Rear Left Turn Signal type to LED. 3061 FRA_H_R_KALTUEBERWACHUNG -> nicht_aktiv : Disabling cold bulb checks for Rear Right Turn Signal. 3061 FRA_H_R_WARMUEBERWACHUNG -> nicht_aktiv : Disabling warm bulb checks for Rear Right Turn Signal. 3061 FRA_H_R_IS_LED -> aktiv : Setting Rear Right Turn Signal type to LED. |
