F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F36 - Led Upgrade - Turn, Backup, Fog
Extreme Powerhouse
      10-19-2015, 04:43 AM   #1
UtilisaE9
Belgium
13
Drives: Various BMW
Hi guys,
I've went through several threads and find ambiguous (different) information regarding the led upgrade.
I'd like to upgrade my F36 with Led for :
- Turn Signal (Front and Rear)
- Backup light
Mine is a F36 420d 2015/10 version.
Can someone confirm the fitment for these lights?
(LIST UPDATED with latest feedback 12/11/15)
  1. Front Signal - PY24W
  2. Rear Signal - P21W
  3. Brake Light - H21W
  4. Reverse Light - PW16W or PW24W
  5. Front Fog - H8
Also I'd like to buy light that does not require coding (just plug & play).
6. Is this possible? => Coding always necessary
7. Is the CREE type a must have? => Highly recommended
8. What Output, 30w, 50w?=> 50W is a must
Thx
      10-19-2015, 10:29 AM   #2
RarScaryFrosty
Drives: 2013 328i xDrive
You can find no-error canbus friendly LED's, but they're still not plug and play unfortunately. In our BMW's they'll flash for roughly 10 seconds every few minutes since the canbus checks if the lights are burned out or not.
The best solution is to just get LED's at a proper wattage that won't melt your wiring/housing, and code out the errors.
      10-19-2015, 11:10 AM   #3
00punisher
Spain
25
Drives: F36 420d
Hi,
I would like to upgrade to LEDs also my F36 07/2015. Reading threads and checking my own car I have found out that:
- Front Signal are PY24W, not PY21W
- Reverse Lights are PW16W, although PW24W are also valid, not P21W
Cree is a must, 50W much better than 30W and coding is always needed.
      11-12-2015, 05:04 AM   #4
UtilisaE9
Belgium
13
Drives: Various BMW
Thank you for you replys!
So to wrap-up on the fitment for a F36 (4 serie Gran Coupe):
  1. Front Signal - PY24W - Confirmed
  2. Rear Signal - P21W? (or PY24W?)
  3. Brake Light - H21W - Confirmed
  4. Reverse Light - PW16W or PW24W - Confirmed
For the CODING I've created a thread on the dedicated forum: http://f30.bimmerpost.com/forums/sho....php?t=1194562
(also this thread is particularly relevant http://f30.bimmerpost.com/forums/sho....php?t=1125832)
Thank you for your help
      11-12-2015, 09:41 AM   #5
tboooe
tboooe's Avatar
925
Drives: F36 428i GC, E36 M3 - gone :(
Rear turn signal is P21W.
My build thread
2015 428i GC - Alpine White - Coral Red - M Sport
      11-13-2015, 12:01 PM   #6
00punisher
Spain
25
Drives: F36 420d
Great thread! Thanks!!
f30post
