2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum Regional Forums USA - Mid-Atlantic Looking to put on new wheels
      10-26-2015, 11:42 PM   #1
Justablackf80
Drives: BSM 2016 M3
Hi, i was wondering what shop down in the NOVA/southern maryland shops can tune my jb4 and put on new wheels. I was going with Zito zs05 19".
      10-27-2015, 05:50 AM   #2
The Ching
The Ching's Avatar
Drives: 2022 G80 6MT
JB4 is an easy DIY
      10-27-2015, 02:13 PM   #3
Justablackf80
Drives: BSM 2016 M3
Originally Posted by slipp3ryching View Post
JB4 is an easy DIY
I cant figure out how to connect my laptop to my jb4. I need to clear the CEL.
      10-28-2015, 10:01 AM   #4
The Ching
The Ching's Avatar
JB4 is an easy DIY
you have the USB cable for your JB4?
      10-29-2015, 12:49 AM   #5
Justablackf80
Drives: BSM 2016 M3
No i dont, could i just get one from Burger tuning?
      10-29-2015, 12:55 AM   #6
Justablackf80
Drives: BSM 2016 M3
would anyone be kind enough to just clear the CEL and put my map setting at map 5?
      10-29-2015, 12:57 AM   #7
Knightelf
Australia
87
Drives: M235i
2011 BMW 135i  [0.00]
Yes you can. But it sounds like you may be better off getting someone more technical to help you. Be careful with the USB cable and don't let it near the battery rail.
Current: 2014 F22 M235i Mineral Grey
Previous: 2011 E82 DCT 135i Space Grey
Build thread: http://www.2addicts.com/forums/showthread.php?t=1149793
      10-29-2015, 12:57 AM   #8
Knightelf
Australia
87
Drives: M235i
Have you actually installed the JB4? You know that you change maps via the steering wheel, right?
For all your JB4 needs, check the first post here:
http://www.n54tech.com/forums/showthread.php?t=18588
      10-29-2015, 01:17 AM   #9
Justablackf80
Drives: BSM 2016 M3
ive tried everything cant seem to get it. im not the most tech savy guy. ive tried holding down the - button and it works, but i just dont know how to see what map its on and the CEL doesnt clear at all.
      10-29-2015, 01:23 AM   #10
Knightelf
Australia
87
Drives: M235i
You can't see what map it's on, you just have to count the number of times you press it (5 times for map 5).
Hold the - for 5 seconds to enter into map mode, then press the + button 5 times.
If you really want to visually confirm it, then you'll need the USB cable connected.
Pretty sure you also need USB cable to clear CEL.
What you need to do is buy the cable, connect it to JB and your laptop, then download the software. Check the link above, it has all the info.
      10-29-2015, 01:26 AM   #11
Justablackf80
Drives: BSM 2016 M3
thank you for the info will buy it right now. i need to get my inspection and with the CEL idk if i can pass it
2addicts
