11-16-2015, 10:17 AM | #1 |
Rep 3,089
LCI AC/radio trim with ambient lighting retrofit
Based on this great thread, I learned that the LCI AC/radio trim piece can be retrofitted to our cars. The best part is that the LCI piece comes with ambient lighting!
Here are some pics of the trim after I installed it this weekend. I am very happy with the way it looks, especially at night. Check out my build thread for more details on the installation. Before: After: Cant get enough LED!
11-16-2015, 07:21 PM | #2 |
80
Rep 346
After I did this mod, something weird is happening on my ride when I start it in the morning. I am hearing like vent sounds and a creaking dashboard.
Did anyone who did this mod experience the same problem? I have double checked and everything seem in order. I have the alcantara trim with the center vents and sounded like it is coming from there. |
11-17-2015, 08:07 AM | #3 |
Rep 3,089
I was afraid of that happening to me as well so when I reinstalled the center vent piece I used some double sided tape to ensure that everything was secure.
11-17-2015, 01:51 PM | #4 |
298
Rep 1,734
Like the 3M stuff you use to attach rear deck spoilers and the lip? Or something a little milder, like the foam stuff you can buy at Home Depot for insulation?
11-17-2015, 02:15 PM | #5 |
Rep 3,089
Yes, I used the good 3m stuff used for spoilers. However, I cut just small pieces no more than 1/4" square to give the trim some adhesion but not so much that I couldn't remove it later.
11-17-2015, 06:03 PM | #7 | |
Rep 3,089
And yes I am also totally anal about squeaks. I have some right now being caused by the door seals rubbing against the windows. I cant seem to pin point a way to resolve it though. I am getting super annoyed.
11-17-2015, 10:26 PM | #8 |
80
Rep 346
I am going to find sometime to remove and install again and maybe loosen it a little on the 4 bolts. If others have done it without any creaking and not having to add anything, I gonna try to redo it again. I will update soonest.
11-27-2015, 02:39 AM | #9 |
80
Rep 346
Just an update. I was able to remove everything needed including the AC trim and reinstalled again. This time I loosen the 4 bolts and made sure I did not over tighten it.
I am not hearing anymore creaking so the AC trim is fine. However, my M Perf CF trim has a little creaking but not all the time so I am just ignoring it for now. |
12-21-2015, 12:13 PM | #10 |
298
Rep 1,734
Ok my parts are arriving today from Christian in Germany. Time to think about installing. So any tips on removing the big trim piece to get started? Are there specific pry points for a panel removal tool? Best place to start? I've seen the YouTube video, but I'm pretty sure it was already unclipped in that vid. They just show someone pulling it away from the dash.
12-22-2015, 10:29 AM | #11 | |
Rep 3,089
12-22-2015, 01:11 PM | #13 |
Rep 3,089
Just my hands. I found some areas where my fingers would fit on the top of the center piece that gave me a good grip to wiggle. Actually I used more a rocking motion vertically. It really does not require that much force at all.
12-22-2015, 01:20 PM | #14 |
298
Rep 1,734
Yep, just my hands. It was pretty easy to remove. Hardest part was the damn connectors. So that's off. Next remove the old trim piece. First the top two screws, then pry the lower trim off to get at the bottom screws....
12-22-2015, 01:55 PM | #15 |
Rep 3,089
GREAT! The hardest part for me was removing the radio and ac units from the old trim. I used to trim removal tools to disengage the clips and pushed on the units while working my way across with the tools.
12-22-2015, 02:25 PM | #16 |
298
Rep 1,734
Almost done! Hardest part for me is getting the damn cables/connectors back in on the main trim piece. That's where I am now. Having lunch first lol. Removing the control panels...I had a pile of credit cards and a thin screwdriver. Not too bad.
12-22-2015, 04:04 PM | #17 |
298
Rep 1,734
And......we're done. All back together, working and no "oh crap's". Thanks for the help tboooe and Dante, who also helped me get the parts from Germany and built the Y harness.
Now if we could just increase the brightness of the door light pipes. |
12-23-2015, 02:57 PM | #19 |
25cent millionaire
252
Rep 1,219
Drives: 2020 m4 comp vert
just did my upgrade. 120 bucks Canadian from Germany. took about 45 min start to finish. very nice and elegant touch at night. didn't use the bmw molex plugs instead I just soldered from new trim to oem wiring.
