2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications M235i Full Splitter Now Installed, See Last Post 11/28/15
View Poll Results: Lightweight Splitter vs. BMW Splitter
Lightweight Splitter 12 54.55%
BMW Splitter 10 45.45%
Voters: 22. You may not vote on this poll
      11-18-2015, 04:48 PM   #1
Spydeputy
Spydeputy's Avatar
Germany
205
Drives: 2015 F23 M235i/2008,E90,335xi
My M235i full Splitter is on it's way from eAs, https://europeanautosource.com/light...-2-series.html .
I like this better than BMW's splitter because, it is fully under the bumper cover, and not covering up a large part of lower outside vent openings.
It doesn't use a ton of 3M tape to hold it in place. Very easy to bolt on and off. Only lowers the car 1/4" from stock.
And "No" I will not put on the Makers "Lightweight" sticker.
Tell what you think, BMW's vs. The Lightweight Splitter?
Pictures to come soon.
      11-18-2015, 05:02 PM   #2
Spydeputy
Spydeputy's Avatar
Germany
205
Vote
What, 11 views in 5 minutes, and No One Votedt?
It's just a click, come on, vote, Thanks!
      11-18-2015, 09:31 PM   #3
s1uma1
Drives: 2015 M235i
Like his better, especially if you were going to paint the splitter body cover and leave the lip black
      11-19-2015, 11:35 AM   #4
Spydeputy
Spydeputy's Avatar
Germany
205
If I paint the splitter (upper section) the color of the car and leave the bottom black, that accomplishes the same thing as Just putting on the lightweight splitter alone does.
BMW's full splitter covers the upper section exactly the same as it is.
That's were all the 3M tape goes.
      11-19-2015, 11:45 AM   #5
alexc93
Drives: na
Light Weight is much nicer. I am biased though.
      11-19-2015, 04:25 PM   #6
NEUE02
NEUE02's Avatar
267
Drives: M235i
I like the Lightweight one better also because of how you retain the color on the OEM part of the front end. I want to see LOTS of pics when you get yours! Maybe even a couple pics detailing the installation process.
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S
      11-19-2015, 11:29 PM   #7
s1uma1
Drives: 2015 M235i
right. so I like the lte lip better bc it achieves the same look as the mpe spotter with less work
      11-20-2015, 04:03 AM   #8
Spydeputy
Spydeputy's Avatar
Germany
205
      11-20-2015, 09:10 AM   #9
crbalch
The Schwab
crbalch's Avatar
Drives: 2020 AW M340xi
2017 BMW X1  [0.00]
2016 BMW M235xi  [0.00]
I did the BMW lip this way, was my personal favorite of all the options/color combos. Left the splitters matte black but did the lip in EBII. I think it gives the car a nice fluid and aggressive look on the front, with a nice piece of contrast in the splitters.
      11-21-2015, 03:57 PM   #10
Spydeputy
Spydeputy's Avatar
Germany
205
Vote Early, Vote Often
      11-24-2015, 04:42 PM   #11
Spydeputy
Spydeputy's Avatar
Germany
205
380 views to date, and only 15 votes???
It takes 15 seconds to vote on this poll.
Splitter came in today, installation on... (Black Friday?) Oh No.
      11-28-2015, 05:30 AM   #12
Spydeputy
Spydeputy's Avatar
Germany
205
LIGHTWEIGHT Splitter Is On
Well this could not be any easier. Half hour, Start to finish.
The splitter is all pre drilled and the holes are countersunk.
I put the car up on rams to work on the underside of the front bumper cover.
Once it was up, you remove the 2 center screws of the bumper cover.
Then insert the 2 long screws provided and drop on the spacers.
Then screw them in place where you just removed the 2 OEM screws.
I checked the end fit on both sides and they were perfect.
I then held the splitter in place and drilled a 1/64" hole threw the under side of the bumper cover where all the pre drilled holes were.
Then screwed in 1" stainless steel screws into each of the 5 holes on each side.
Starting with the outside working in.
The fit is perfect from end to end.
It really finishes off the M bumper without changing, or covering anything.
The thickness of the LIGHTWEIGHT splitter is 3/8" on an inch, so that is all that it lowers the front of the car.
This is by far the best Cosmetic Mod I have done to my car.
ps. They did provide nice screws, but there was no place to a machine thread screw. (see pic)
Good thing I had stainless steel sheet metal screws on hand.
      11-28-2015, 03:32 PM   #13
NEUE02
NEUE02's Avatar
267
Drives: M235i
^^^ EXCELLENT! Great job and we all appreciate the DIY and photos. Thanks for the effort. Looks fantastic!
The Stable
      11-30-2015, 10:07 AM   #14
Luminous
Luminous's Avatar
743
Drives: 2019 M5 Competition
Thanks for the pics and DIY. I just ordered this splitter so I appreciate the pics. My only question is why you had to drill another hole?
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      11-30-2015, 10:44 AM   #15
ScBlacksunshine
YUGO is my dream car
ScBlacksunshine's Avatar
144
Drives: Bayerische Motoren Werke
I like the lightweight front lip a lot. Do you have to jack up your car or put it on a lift to get access to the bolts underneath? Can I install it without jacking up the car?
      11-30-2015, 10:55 AM   #16
Spydeputy
Spydeputy's Avatar
Germany
205
I just made a short ramp with 2 2"X6"X4' and 3 bricks on each side.
Just to get me ample room underneath.
      11-30-2015, 10:57 AM   #17
Spydeputy
Spydeputy's Avatar
Germany
205
You have to drill 5 holes on each side.
My DIY explains that. GL
Super easy to do.
      12-23-2015, 02:23 PM   #18
CanadianGatorBacon
CanadianGatorBacon's Avatar
Drives: M235i (holy crap!)
Why couldn't you use the machine screws?
Current: 2016 BMW M235i | 2013 BMW X1 xDrive28i (wife's)
Gone but not forgotten: 1992 Buick LeSaber Limited | 1999 Acura CL 3.0 | 2003 Volvo S60 2.4T | 2006 BMW x3 3.0i | 2009 Honda Fit Sport
      12-23-2015, 02:31 PM   #19
Spydeputy
Spydeputy's Avatar
Germany
205
There are no machine threaded holes under the bumper cover in the area where the splitter goes.
Get some nice short (1") stainless steel screws, except where the extension tube go, use 2".
drive up to MD and i'll give you a hand.
      12-29-2015, 08:37 AM   #20
CanadianGatorBacon
Thanks! Don't have one yet, but if I get one I might take you up one that.
2addicts
