BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Attention Oil Junkies
      01-31-2006, 10:57 AM   #1
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
http://www.mr2.com/ARTICLE/Mobil1.html
On side note. Ne1 know if it's ok to use non-synthetic oil if you're going to change your oil every 5k miles?
      01-31-2006, 03:35 PM   #2
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
why would you? Cheaper? With the temp fluctuations, synthetic gives better viscosity and proetection throughout seasonal temp variation... even in
Hot-lanta
"Teach the ignorant. Ignore the stupid."
      02-02-2006, 11:01 AM   #3
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Hot-lanta
You are correct. The reason why BMW uses synthetic and therefore recommends 15k oil changes is precisely due to the properties you mentioned.
My arguement is that changing the oil on these cars every 3-5k miles negates the benefits of synthetic. I would even go so far to suggest that when the oil is changed that frequently (ie.3-5k miles) engine wear or lack thereof is exactly the same regardless of whether or not you use synthetic.
If this is true, then why spend the $$ on synthetic if you're going to do more frequent changes. You could potentially cost yourself 2x the $ for no add'l benefit.
I just don't know.
      02-02-2006, 11:23 AM   #4
younghov85
Drives: 2006 E90 black 325
I think using non-syn. oil would do more neg. that pos. even if u do change it more frequently. Just as it does damage to an engine such as the e90 if you use 87 octane instead of 93 octane. Plus its much cheaper! 15,000mi.=$80-$100 or 3,000mi.=$25-$30. Thats $125-$150 for regular oil changes, which makes synthetic oil changes much better.
      02-02-2006, 12:49 PM   #5
RBBMWE46M3
blaupunkt
RBBMWE46M3's Avatar
Drives: 2008 335xi 6spman montego
2008 x5  [0.00]
1972 R75/5  [0.00]
2008 335xi  [0.00]
how do you figure that if you change the oil every 3-5 k it is not good ? Does synthetic need to be in longer to be effective?
BMW ENGINEERS
      02-02-2006, 01:07 PM   #6
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Naw..I what I'm trying to say is the reason why you use synthetic is to get prolonged change intervals. You're spending more $ on oil but changing the oil less frequently. If you're going to change the oil more often (3-5k miles) you're not realizing the full benefit of using synthetic.
Am I making sense?
      02-02-2006, 01:09 PM   #7
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
That's the thing..we just don't know. I believe BMW didn't switch to synthetic oil until they extended the change interval to 15k miles.
I'd really like an Oil Guru to give us the lowdown.
