11-28-2015, 06:41 PM | #1 |
Rep 9
Stock exhaust with M Performance diffuser
I installed a M Performance rear diffuser yesterday and I was wondering if I will need to buy new tips for the stock exhaust. The tips are not close to touching the diffuser but I don't want to run into any problems later.
11-28-2015, 07:36 PM | #2 |
Gettin It Figured Out
1820
Rep 2,669
You'll be fine with stock tips. Diffuser was developed for the larger "M" performance tips. You'll just have a little space top to bottom - side to side.
11-28-2015, 08:14 PM | #3 |
Rep 9
Ok, thanks. I knew the diffuser was made for the M Performance exhaust, which is why I was wondering if I would need tips that stick out further to match the length of the M Performance exhaust. I just wanted to make sure the diffuser wouldn't get too hot and melt. As you mentioned, there is now more room between the diffuser and the exhaust tips, so hopefully I should be good.
11-28-2015, 09:40 PM | #4 |
Rep 3,089
I got larger 3.5" exhaust tips and adjusted my muffler so that the tips are less than 1/4" away from the diffuser. Never had an issue with heat. Also, I am pretty sure you can adjust the stock exhaust tips a bit too in order to bring time out further.
