Eldor BMW OEM Coils 12138657273
12-04-2015, 11:02 PM | #1 | |
469
Rep 4,392
First and most of all credit goes to Jklad about the new BMW OEM Coil for our cars. I am just confirming the findings, and yes I installed them on my car. Roads were a bit wet down here so wasn't able to go all out and not land into a palm tree
The NEW BMW ignition coil part number 12138657273 for the N54 is NOT made by Bosch, it is made by Eldor. This part number is the same coil used many many many other BMW, Mini and Rolls Royce cars. Surprisingly it the same coil used on the new Rolls Royce Wraith that puts out 625 hp Source: http://www.realoem.com/bmw/enUS/part...&q=12138657273 I had a bad batch of Bosch plugs I got that only lasted less than 2 months. I couldn't bare it anymore after I got a replacement plug but turned out most of the plugs were bad. So I gave up playing cat and mouse and just decided to go to the dealer to get the new coils There is dramatically a BIG difference in quality between the Bosch/BMW vs the Eldor/BMW coil The Eldor snugged more tightly on the plug and is significantly heavier and more solid than the previous Bosch version Yes that is a black metal wrapping around the coil like the Delphi that is gray I am running these with the new NGK plugs, discussion of that I posted in another thread but here is the quote for reference Quote:
12-04-2015, 11:51 PM | #3 |
469
Rep 4,392
12-04-2015, 11:54 PM | #4 | ||
Rep 56
12-05-2015, 01:27 AM | #5 |
184
Rep 1,702
Drives: Audi TTRS, 335is
Interesting. I wonder why BMW still uses the Delphi on some of their high performance applications like the M3, M4, X5M, X6M.
12-05-2015, 05:51 AM | #6 |
Rep 715
This is same as I got when I looked at our alternative BMW parts supplier here in Norway.
But I ordered the Delphis instead , way cheaper and should do the trick here. If not , Eldors next
Vargas S2 turbos|VAC S3 Cylinder head|RR DPs|RR MPs|Supersprint X pipe|Remus Quad Sport mufflers|aFe Stage 2 Si with scoops|Forge DVs|ER CP|BMS meth elbow|Aquamist HFS-4|Walbro 450 E85 LPFP|AA FMIC|BMS OCC|MHD|P3 Boost Gauge|Ohlins Road & Track + camberplates|M3 sways F/R+ Ground control endlinks|Vorsteiner v303 19"|Michelin PS2 sport|Quaife LSD|Vorsteiner V35 CF hood|CF CLS trunk|Duke Dynamics quad diffusor
12-05-2015, 12:36 PM | #7 |
48
Rep 361
Interesting, was looking at the newest part number from realoem as well and landed on this page. Eldors it is, thanks!
Now to find a supplier shipping here up north. |
12-05-2015, 02:03 PM | #8 | |
Rep 56
12-05-2015, 04:52 PM | #10 | |
469
Rep 4,392
Delphi coils were a better choice than the Bosch, no doubt, then this year BMW changed to Eldor instead of Delphi for all related cars including Rolls Royce. Another question is why not Delphi in their Rolls Royce ? |
12-05-2015, 05:14 PM | #11 |
469
Rep 1,536
What do you think caused your Bosch coils to die after 2 months? Think it's the extra heat in the engine bay from the tune?
I just ordered a new set of Bosch coils as preventative maintenance, if I knew about these last week I would have certainly gotten Eldor coils instead. |
12-05-2015, 10:57 PM | #12 | |
469
Rep 4,392
I think it's just quality control and less core winding compared to the Delphi and and Eldor coils Whoever or wherever you got your backup coils from call up and ask if you can return them and pay the difference for the Eldor coils |
12-07-2015, 01:46 PM | #13 |
Retired and Enjoying it
52
Rep 170
FYI if you are covered by BMW warranty (normal, cpo, or wrap) BMW will only replace with parts (coil) spelled out for that particular model. They can not substitute. I just lost my 2nd replacement coil in 13,000 mi. Bosh installed, could not put Delphi in. 6 Eldor on order.
2011 35i BMS High & Low side OCC, Custom tune, CDV delete, Eldor coils, ER Charge Pipe w/Tial BOV, ER Comp. FMIC, K&N drop in,40W LED Halo, LCI side markers, M-Factory LSD, NGK plugs, Racing Dynamics strut brace, Stubby, Windrestrictor
12-07-2015, 06:01 PM | #14 |
Rep 695
12-23-2015, 08:01 PM | #15 |
102
Rep 1,903
Drives: e92 335i 6MT
I wonder if it would be a bad idea to mix with existing with Bosch coils? Anyone know if it is recommended or required to swap out all 6 if switching to these?
12-29-2015, 09:08 AM | #16 |
Rep 228
Drives: E92 07 335i
Thanks for this - do you have information about dwell time? someone pointed out that the GN10328 coils have a longer dwell time vs OEM bosch N54 coils, so I wanted to know how the Eldors fare.
12-29-2015, 12:34 PM | #17 |
469
Rep 4,392
No specs available, I did however send the company an email requesting the info but won't get a reply till after 1/6/2016
12-30-2015, 07:08 AM | #18 |
469
Rep 4,392
NGK gaping, nothing different from the traditional gaping. Personally me I gapped mine a bit more tighter. Between .020" - .022" gap is fine, just make sure to take.................. your................ time.................... and be delicate with the heads
I used another gauge to pry and set the gap Last edited by BQTuning; 04-11-2016 at 09:41 AM.. |
N54Society448.50 |
01-09-2016, 10:20 PM | #19 | |
Rep 648
Drives: 2012 335is
2012 E92 335is | BSM/Coral Red | Moonroof Delete | 6MT BQ Tuning | ar design DPs | M Performance Spoiler | Michelin PSS | Cyba Ram Air | VRSF CP | Fuel-It! Stg 2 LPFP Split Armrest | LUX Reverse Lights | Rear Fog Lights Enabled TOOK DELIVERY 24 OCT 2011 [FIRST PICS] [INTERIOR PICS] |
01-10-2016, 12:03 AM | #20 |
Rep 1,039
Or you can get e46 m3 coil packs for about $25 each
https://www.fcpeuro.com/products/bmw...cOEaAu-E8P8HAQ |
01-10-2016, 12:16 AM | #21 |
Rep 1,341
I am actually running 1 of these new Eldor coils with the rest being Bosch. Have had no issues car running strong.
I did notice the quality difference is very apparent. Also the metal part that contacts the spark plug seamed to a lot better quality that the Bosch as well.
IG:@DMAGARAGE - 2003 E46 M3 | 2009 E92 M3 | 2016 F80 M3 |
01-10-2016, 10:11 AM | #22 |
469
Rep 4,392
