12-20-2015, 05:36 PM | #1 |
25cent millionaire
252
Rep 1,219
Drives: 2020 m4 comp vert
led headlights
has anyone tried the wiesslicht illuminato low beam led bulbs in our f 30 cars. they are expensive, but look very well built, and they say are engineered specifically for our cars. iam just trying to decide on these bulbs or a top notch hid 35watt canbus hid kit.
12-21-2015, 08:05 AM | #2 |
Rep 700
I didn't have these exact bulbs, but I had a rebranded version. The ones I had were the Philips led's, light output was great, not too much glare, just didn't much care for the beam pattern. They did flicker at startup, but I coded all of that out.
12-23-2015, 03:17 PM | #3 |
25cent millionaire
252
Rep 1,219
thanks Adamr 916 food for thought.
12-23-2015, 03:52 PM | #4 |
79
Rep 312
I own these lights like adam, another rebadge. Don't buy the ones you linked, buy these instead.
http://www.amazon.com/JDM-ASTAR-Gene...=jdmaastar+6th I've had a great experience with them, but I also had to code out all checks/errors. Any aftermarket kit will typically give you errors. I had to have a friend code out the cold/warm checks for the low beam and high beams so I didn't get errors. They work fantastic and are much better than the stock halogen H7 bulbs. |
12-23-2015, 08:51 PM | #7 |
Rep 2,036
So .....were you guys able to install via wheel well or did you remove front bumper and actually take the headlamps out and do your install?
12-29-2015, 04:56 AM | #9 | ||
Rep 968
I have replaced all front and rear bulbs to LED's except low beam and high beam. Couldn't find any good replacement earlier. Here are the other LED's I have used. http://f30.bimmerpost.com/forums/sho....php?t=1194602 Thanks |
12-30-2015, 01:03 AM | #11 |
Rep 968
12-30-2015, 08:04 AM | #12 |
Rep 700
I believe I have the Philips bulbs, but it looks like they changed to the Cree bulbs.
Boltlink H7 Ultra Bright Led Headlamp Cree, H7 12v 40w Led Headlights Bulbs 5000lm Led Headlight, H7 6000k Pack of 2, Replaces Halogen & HID Bulbs https://www.amazon.com/dp/B00NSUDF2E..._er-GwbXQTGJ27 |
