01-11-2016, 09:09 PM | #1 |
25cent millionaire
252
Rep 1,219
Drives: 2020 m4 comp vert
oem to led high beam.
hey guys just got my gen 5 phillips 2500 lm h7 led lights. installed just one in the high beam housing to test the output. turned on car and bing bing bing, bulb check indicator came on immediately. I knew that would happen, gonna order some 50 watt 6ohm resistors to eliminate this issue. but now for the real test. measured the light output at 3 ft. with my metre. Pass. side with led. 2350lm. not quit 2500 lm but close enough for rock and roll. now the high beam driver side. 2150 lm. so that's a 35 watt led vs a 55watt halogen. well done led.. well done.
01-11-2016, 10:12 PM | #3 |
25cent millionaire
252
Rep 1,219
thanks Adam what I realty need is someone to due a complete tutorial starting from uploading the data to your laptop, to plugging it in to the obd sensor, and start up to shut down of programming, I have watched all of them on youtube, and still not enough info for me. Like I said befor, I have everything loaded on my laptop, I bought a cable I just don't know the proper order on what due and where to go for deleting and adding,
01-18-2016, 09:01 AM | #6 |
Rep 700
01-18-2016, 09:32 AM | #7 |
Rep 1,436
