01-25-2016, 03:49 AM | #1 |
Rep 265
Cheap LED turn signals?
Hi,
I have done some searching and found a few threads discussing this subject. But most of them are pretty old. And all I find is people suggesting pretty expensive LED-lights, $60 for 2x. Anybody who have tried cheaper alternatives that work great in the front and in the rear? I have an ENET-cable so I can do the coding. Would love to hear your thoughts, and please link to the product you have tested. Pictures is much appreciated too! |
01-25-2016, 04:35 AM | #2 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
Nobody has had any legit success with "cheap" turn signals. They're either way too dim, don't work, or don't last long and cause errors. $60 for 2 isn't a bad deal, considering they should last the life of your car, they're brighter, AND they're LED...gotta pay to play. I'm not sure which bulbs you're referring too for $60 but these are the ones I havehttps://bimmian.com/Accessories-for-BMW/Lighting/Turn-Signal-Lights/LED-Turn-Signal-Bulbs/
and I love them. Replaced fronts, rears and reverse lights, also a lifetime warranty! never have to buy another bulb again.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
01-25-2016, 12:15 PM | #4 |
Rep 700
I too have had great experience with the Weisslicht bulbs off of bimmian. $100 for a pair, and you get a lifetime warranty with them. I have 30 watt turns all around and 30 watt brake lights, and they are by far brighter than the 50 watt bulbs I bought from Horizion.
Just remember, you bought a BMW, not a honda. No sense in going cheap on something when it will just make your car look bad. |
01-26-2016, 12:49 PM | #5 |
Rep 279
I only changed my brake lights and rear signals. These bulbs are bright and great quality IMO. You just need to code them so they don't blink every so often (typical for every LED bulb swap).
http://www.amazon.com/gp/product/B01...ilpage_o00_s00 http://www.amazon.com/gp/product/B01...ilpage_o00_s00 |
01-26-2016, 06:19 PM | #6 |
Rep 1,134
I got some cheap ones from jtechnowcom on eBay. While not a direct match with the xenons, I've had them for almost a year now and they're still good. Only cost me $25
01-27-2016, 12:42 AM | #7 |
Rep 265
01-27-2016, 10:01 AM | #8 | |
Rep 1,134
If I was to go back, I would probably have taken my time and gotten something better, quality wise. I do believe I had to send back a bulb or two until I got two good bulbs. But yeah, as you can see, not a perfect match but I didn't spend enough time searching for a good bulb. Bought the first one I saw haha |
04-30-2016, 12:38 PM | #10 | |
Rep 231
05-03-2016, 10:27 PM | #11 |
Rep 279
05-04-2016, 06:02 AM | #12 |
BMW Fanatic
331
Rep 1,076
Those are for the F30. He has an F36. I believe they are H21W-435 for an F36, unless they are different than a F32. I've changed all bulbs (except for rear fogs) from Horizon + Bimmian. Nothing but great things to say about both companies.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
05-04-2016, 06:06 AM | #13 | |
BMW Fanatic
331
Rep 1,076
05-04-2016, 07:37 PM | #14 |
Rep 1,479
Drives: 2020 M340Xi (G20)
On my 2014 F30, I have replaced back up & Rear turn signals with Weisslicht LEDS from Bimmian; went with amber rear turns. Coding to eliminate flicker was very straight forward
While these bulbs are more than others but have lifetime replacement guarantee |
05-06-2016, 10:48 AM | #15 |
Rep 926
I got these.. really nice and bright http://www.ebay.ca/itm/Best-2-x-1156...NTVi0r&vxp=mtr $20 shipped
05-06-2016, 12:01 PM | #16 |
A family of bimmers
2747
Rep 7,742
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
05-07-2016, 07:04 AM | #17 | |
Rep 231
05-07-2016, 11:16 AM | #18 |
BMW Fanatic
331
Rep 1,076
Forgot to mention I was talking about the brake lights only. Reverse lights are PW24W on the F32. Should be the same on the F36. Owner's manual has it as PW16W but PW24W fits perfectly and operates as expected.
05-09-2016, 08:48 AM | #19 | |
A family of bimmers
2747
Rep 7,742
