CBU cleaning with WURTH chemicals
02-29-2016, 07:17 PM | #1 |
14
Rep 33
Hello
My local shop says they use Wurth chemicals instead of walnut shell blasting to clean the CBU. Anybody know anything about this? |
02-29-2016, 07:56 PM | #2 |
Rep 291
Probably something like this?
I have tried something similar from Liqui Molly, not sure about result, ended up to take out the intake and clean it manually. I would say this type of cleaning could be used as preventive let say at oil changes. But if the problem exist it will not dissolve it PS This is only my opinion, i am not a technician so i am probably wrong. |
02-29-2016, 08:37 PM | #3 |
COAL FED
74
Rep 300
Have them show you before and after pictures. I would be interested in knowing if this really does anything helpful. It might supplement blasting, but I have my doubts that it could replace walnut blasting. I could be wrong though.
I have a couple concerns with something like this 1) All of that carbon will be stripped away from the intake manifold/valves/head and be sent through the turbos, DPF, and Catalyst potentially creating a major blockage issue. 2) Will this even work on our diesel? What is the fuel pressure required for the M57? Would that can even provide the necessary pressures?
02-29-2016, 08:47 PM | #4 |
102
Rep 320
You're missing the obvious. This particular method would do nothing for CBU in the intake because the chemical is delivered as fuel. In order to clean CBU, the cleaner would have to be carried by the air through the intake manifold, not by the fuel through the injectors.
02-29-2016, 08:55 PM | #5 | ||
Rep 291
We are not speaking about fuel system This is what i have used, probably it is something similar. |
02-29-2016, 09:19 PM | #6 | |
COAL FED
74
Rep 300
03-01-2016, 07:15 AM | #8 |
14
Rep 33
Thanks for the feedback
From what they told me they are removing the intake manifold rotating the engine so the valves are closed and soaking the ports with this then removing and repeating the cycle for each intake. I'll let you know more tomorrow when I take it in. And ask for pictures :-) |
03-01-2016, 07:56 AM | #9 |
Rep 291
03-01-2016, 07:57 AM | #10 | |
Rep 291
Interested in results. |
03-01-2016, 08:51 AM | #11 | |
389
Rep 1,623
03-01-2016, 08:58 AM | #12 | |
Rep 291
I was washing my EGR valve, first i was trying to use some kind of brake cleaner, after that i have got a carb cleaner, it worked better, but still didn't do its job. Finally i have bought a gallon can of some dipping carb cleaner in walmart, after a day in that stuff EGR valve came out dirty but all the buildup was dissolved. So my message is that the right chemicals can do a job, maybe not the perfect one, but very good one. And no reason to make perfect one if it will be messed up up after first thousand miles. |
03-01-2016, 09:55 AM | #14 | |
389
Rep 1,623
03-01-2016, 10:17 AM | #15 | |
Rep 291
My plan is to install meth injection and let it clean by it self |
03-01-2016, 10:21 AM | #16 | |
389
Rep 1,623
It's a very simple process. The hardest part is removing the intake. Last edited by 335dsleeper; 03-01-2016 at 10:27 AM.. |
03-11-2016, 08:31 AM | #17 |
14
Rep 33
Cleaning done
Got delayed a week but finally got the CBU cleaning done using chemicals.
It took him longer than planned, he said it was worse than others he has done. however in the end the price was good and the pics look good. Engine feels a little stronger and now to see if I get some MPG back. |
03-12-2016, 07:02 PM | #20 | |
COAL FED
74
Rep 300
Not bad.
03-12-2016, 08:28 PM | #21 | |
389
Rep 1,623
