2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications Car keyed
      03-01-2016, 06:39 PM   #1
yatesfloyd
Drives: 2016 BMW 228i
Car keyed
I'm in high school so it's not like it's out of the ordinary, but does anyone know/use a paint scratch/chip repairer (I have black sapphire if it makes any difference)? It's only a small, but semi-deep scratch on the trunk that's noticeable close up and I want to try and fill it in/cover it up.
      03-01-2016, 07:24 PM   #2
GmaineG80
GmaineG80's Avatar
Drives: 2023 BMW M3 Comp X-Drive
Try Dr.ColorChip....I buy a set for every car I own it works great.
      03-01-2016, 09:56 PM   #3
tenfour
Drives: at the speed limit
How deep is it? May possibly be able to just buff it out.
      03-02-2016, 12:18 AM   #4
yatesfloyd
Here is one of them (the worst)
      03-02-2016, 05:35 AM   #5
Total madness
Total madness's Avatar
60
Drives: M235i EB2
Just for the record : driving a new 2 series In high school ?
      03-02-2016, 07:12 AM   #6
overcoil
Drives: M235i 6spd
If you try to fix it yourself it's likely any fix will be noticeable.
Main issue is metallic paint in itself is hard to blend
Second issue is smoothing the repaired surface to where it blends. Most likely wet sanding after painting the scratch is the best way - need experience.
The scratch doesn't look to bad in terms of defacing the trunk lid. First try compounding or polishing - go to a detailing site/forum.
If you attempt yourself ( worse comes to worse have a shop do a respray ) buy a used metallic painted trunk lid at a junk yard or car recycler, and attempt repairs. Try air-brushing and wet sanding, or Lanka/Color-Chip etcetera.
Also, don't worry yourself about it. It looks like a small scratch and sometimes it's best to just leave it. I really like the car color.
      03-02-2016, 09:54 AM   #7
yatesfloyd
Yep
      03-02-2016, 09:55 AM   #8
yatesfloyd
Ya I figured it would be best to either leave it or go pay for it to get fixed.... Thanks
2addicts
