Coilovers official thread
03-02-2016, 05:07 PM | #1 |
Rep 180
What options are there for the 335d lci Coilovers? Stainless is a must, looking to drop the car about and inch or so, and improve overall handling.
I was considering KW V1's (as I do not plan to track the car) but I don't believe they make a specific package for the 335d? (Not sure about spring rates or fitment) The places I've been checking say they are for the 335i's. As I have not ruled anything out yet, and I would also like this to be a good resource for others, please share thoughts/experiences with any sets ups good or bad. |
03-02-2016, 05:29 PM | #2 |
389
Rep 1,623
I have ST coil overs and for the money, they're phenomenal. Better ride than stock and much more responsive. Might want to look in the classified section, all 3 series stuff fits (minus M3) an you can save a bunch of money getting a lightly used set.
03-02-2016, 05:41 PM | #4 | |
Rep 292
Drives: 2011 335d
Garage List 2017 Audi Q7 [0.00]
2011 BMW 335d [0.00] 2006 Nissan Titan SE [0.00] 2008 MB CLS550 [0.00] 2012 BMW X5 SAV [0.00] |
I have Ohlins R&T w/ Swift Spring upgrades, which is more of a track oriented set up when it needs to be. There are no coilover kits that are specific for an E90 335d, only springs from H&R. You can basically use anything that is compatible with an E90 335i suspension wise. Many people have had good experiences with ST on the lower end of the budget scale, KW suspensions are a very popular choice along with the increased adoption of Ohlins setup. There are also people running coilover setups from H&R, Eibach, Ground Control, etc. You will be able to find a lot more info in the E90 suspension sub forum. |
03-02-2016, 05:47 PM | #5 | ||
Rep 180
03-02-2016, 06:13 PM | #6 | |||
Rep 292
Drives: 2011 335d
If you are trying to stiffen up the spring rates then switch the springs to Swift w/ the appropriate rates you are looking for. |
03-02-2016, 07:11 PM | #7 | ||||
Rep 180
If this is true, this is helpful |
03-02-2016, 08:22 PM | #8 |
88
Rep 358
I will reiterate that all the 335i rwd stuff fits. Vendors that say it won't are wrong and simply don't know any better.
As far as the extra weight of our cars, it's only about 200 lbs and the weight distribution front to rear is nearly identical to the 335i and within 1% of 50/50. So unless you are trying to squeeze the last 0.1% out of the car on the track you will be perfectly fine installing a 335i setup that meets your desired levels of comfort and handling. |
03-03-2016, 07:41 AM | #10 | |
Rep 180
I also read about BC's, H&R's, and a few other cheaper brands, but from my understanding it sounds like people have problems with them, they don't hold up the same, and people complain about noise from suspension. I've heard mostly good reviews on the FSD's paired with springs, but there is no adjustment with this kind of set up. |
03-03-2016, 09:27 AM | #14 | |
88
Rep 358
Former situation you might only get 50K, latter you can probably go over 100K and they'll still be in decent shape. I've been researching this a lot lately and based on what I've read around here and in other forums, 75-100K seems to be when the stock units start to let go. |
03-07-2016, 02:13 PM | #15 | ||
Rep 1,442
03-07-2016, 02:15 PM | #16 |
Clean is the new cool, keep it that way.
808
Rep 1,684
I plan on getting the Bilstein PSS this month. My second choice was the ST's.
2011 335i, FBO, N55+ Turbo, full E85, S55 intercooler, etc.
2015 X5 35i Xdrive |
03-07-2016, 02:24 PM | #17 | |
Rep 180
