03-09-2016, 06:35 AM | #1 |
Rep 4,516
Why no KW HAS for M235i
I think F8x HAS from KW is smart upgrade designed to compliment OE adaptive dampers.
http://f80.bimmerpost.com/forums/sho....php?t=1235270 If KW have designed OE M2 coilovers - how hard can it be for them to tweak spring rates to come up with a HAS for M235i ? Or am I missing something ?
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
03-09-2016, 04:33 PM | #2 | |
Rep 2,942
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
03-10-2016, 02:39 AM | #3 | |
Rep 4,516
I know M2 has a passive setup but M235i [and M135i outside USA] have adaptive. Your logic quoted above is flawed IMHO given that F8x M3/M4 has OE adaptive damping and KW HAS seems to work really with it. Hence my Q why no KW HAS for M235i with adaptive..I would fit it to my adaptive damped car. BP
03-10-2016, 09:26 AM | #4 | |
Rep 2,942
Your comment to 'tweak' the existing HAS for the M235i may very well be possible by KW. But now that the M2 is out, it's probably not a priority for it.
03-10-2016, 11:02 AM | #5 | |
Rep 4,516
Based on mine and other early adopters feedback, many others have followed suit and not looked back. So, whilst I respect your point of view, don't knock it until you have tried it - its a superb OE upgrade, even for a stock car. The ~ 15mm longer LCA moves the wheel fwd ~ 1/2 inch and castor and camber is increased with very positive results on steering feel / directness and increased longevity of the soft outer shoulder of std fit Mich PSS. My car runs ~ -2deg camber and runs straight and true as both a DD and on trackdays. Other upgrades incl LSD, upgraded springs and ARB's. If you are nearby I'd gladly take you for a blast in it. Going back to HAS, F2x OE adaptive dampers do respond well to some upgraded springs hence why I think KW are missing a big opportunity - HAS for Mx35i - come KW get it done !!!
