Charge air temperature sensor
03-15-2016, 01:33 PM | #1 |
Rep 13
Well it looks like I'm trading one error code for another as I go chasing codes...
I just took off my intake manifold and cleaned the intake, erg, throttle body, and the swirl flaps... to get rid of swirl flap actuator codes and smoothness regulator error codes on cylinder 4 and 2. Those codes are now gone and I am left with a temperature sensor code, now everything is connected but shoot maybe this shorted...? Is this number 12 here? http://www.realoem.com/bmw/enUS/show...88#11617812274 Error codes 4390 Charge air temperature sensor Sigh, the effects while driving are around 1700-2000 rpms power quits and jolts forward... lunges on and off... I got rid of charge pressure control error 4530 by removing my jbd. Any thoughts, or ideas? |
03-15-2016, 02:10 PM | #3 |
Rep 13
Thanks for the clarity!
03-16-2016, 08:32 AM | #5 |
Rep 3,489
Drives: Montego Blue 335d
greta thinkin sukutash
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
03-16-2016, 10:20 AM | #7 |
66
Rep 364
I do this with ALL my parts and has saved me thousands. I worked in the parts dept at multiple dealerships and some parts are marked up hundreds of percent. There is plenty of wiggle/negotiating room, they only want to know that your haven't arbitrarily pulled a number out of thin air.
03-16-2016, 09:57 PM | #8 | |
Rep 13
03-16-2016, 10:02 PM | #9 |
Rep 13
What approach did you go about replacing the Charge Air Temperature Sensor? I'm just going from the top, looking down in the hood, my current wiring "clip" just slid off the old sensor too easy - willy nilly - It looks like the white part on the clip that goes into the sensor isn't doing it's job. Does the sensor just easily pull out of the pipe? tired of breaking things
03-17-2016, 09:48 AM | #10 | |
Rep 217
03-17-2016, 10:04 AM | #11 | |
Rep 3,553
Reading your message tells me you are trying to put clip back with white thing still there. Try to remove white thing without breaking anything and then insert the clip. After this, put white thing back in. That worked for me. When I read this thread earlier, I was going to suggest you make sure you had a good connection from clip to sensor. It would suck to replace sensor and old one be just fine. Good luck! |
03-17-2016, 06:24 PM | #12 | |
Rep 13
and the throttle body also has a small pool of oil in there too. Oil is right at the max line did a change about 3,000 miles ago. I just got done cleaning out the manifold and swirl flaps. How much oil is expected to be in the charge pipe??? At least I'm getting what I think is normal idle MAF sensor readings, with the charge temp out it was reading 12-14 g/s during idle, now it's around 8. Before After new charge pipe temp sensor Code is gone now! And so is the Check Engine Light. Just chasing the DSC inactive error 5E5B ... One step at a time! |
04-11-2016, 03:51 AM | #13 | |
Rep 1,442
Tags |
4390, charge air temperature sensor |
