EDC16cp35 Vs EDC17cp09
03-15-2016, 09:07 PM | #1 |
865
Rep 642
Well, during my R&D I thought to myself "how much better is the euro 335D tune over the US spec". So, I decided for 335D community to find out. For the past month I have decoded all the maps needed to convert the euro 335D edc16 stock tune over to the US spec edc17 and see if it really makes 21hp more on the dyno.
Here's some side by side maps to take a look at. Boost Maps Driver's Wish Rail Pressure It seems boost is a mix bag, since the edc16 only has 10 or so maps vs the edc17 that as 28. At the top end of the boost maps, they seem to match up for the most part. The euro Driver wish maps are more aggressive over the US counterpart. As for the fueling, the maps are identical for rail pressure. I will update with more side by sides soon(SOI, N75 and smoke) |
03-16-2016, 09:06 AM | #4 |
Rudolf/German/Compression Ignition Specialist.
53
Rep 168
how do the egr maps compare? I always wondered if it was the chicken or the egg debate with the euro cars and the less likeliness to cbu.
Is it the fuel? (most likely considering you said they are similar) Is it the egr map? or is it the boost with the egr that makes the difference? Also how does the us drivers wish in sport mode compare to the euro regular drivers wish?
I fix other people's stupid German problems so I can afford to fix my stupid German problems....
03-16-2016, 10:46 AM | #5 |
Rep 579
What they've done with boost management seems a bit odd to me, based on what I see. My car has a cold running issue, where boost jumps around erratically on throttle application at low-to-moderate load for the 1st 5-10 minutes before it warms up. You can't feel it, appears to run normally, just see it on the mechanical boost gauge. I want to believe it's a hardware problem with the wastegate(s) waiting to actually break, but something makes the phenomenon disappears after warmup.
Then there's an arbitrarily stupid (to me, at least) boost limit the DDE appears to transmit to the wastegates somehow. Pull out moderately hard from a stoplight, it jumps to 20psi and settles. Do this at 30%, 40%, 50% 60-70-80% throttle, doesn't make any difference - same real life boost application pattern - jumps to 20 then settles wherever it needs to be. The only way it gives more than 20psi is at max load, full throttle, or nearabouts in that range. How do you translate that from digital to analog? Dunno... |
03-16-2016, 11:58 AM | #7 |
865
Rep 642
03-16-2016, 01:52 PM | #8 |
Rep 462
03-16-2016, 06:21 PM | #9 | |
865
Rep 642
As for the drivers wish boost maps "sport mode", the euro version is a little more aggressive vs the US spec. next dyno tune I do, (with the owners permission) I want to load the euro tune and see how much more it makes over ours. |
03-17-2016, 04:22 PM | #10 |
Rep 157
Important is the components of which the motor is built. Not the software version, that is used. Important is to know and understand, how the engine actually works. Not the software version, that is used. The software is only a tool to control the engine. In both softwares have the same thing told in a slightly different ways. Only real difference is that your cars urea additive. Who understand, how the lambda-controlled edc-16 program works, have no real difficulties to do decent edc-17 program, they are so similar. Same things in both ecus, different order. |
03-17-2016, 04:58 PM | #11 | |
389
Rep 1,623
03-17-2016, 09:52 PM | #12 | |
53
Rep 168
Interested in the results...
03-17-2016, 09:56 PM | #13 |
389
Rep 1,623
03-18-2016, 12:45 AM | #14 | |
Rep 157
Helps also a lot if you can compare two almoust similar softwares with and without additives, dpf, intake flaps ... |
04-06-2016, 09:42 AM | #15 |
865
Rep 642
The Results are in and I hate to be right The US 335D makes the same power as the Euro 335D
I converted all the EDC16 maps over, its 1:1 to the EDC17 and made the SAME peak HP & TQ. So, what does this tell us? It says BMW underrated the US Spec, meaning the US version of the D makes 286 Crank HP, not 265. If you take a look at the graph, you can see the euro tune makes more power in the middle of the band. If you think the exhaust is why the euro version makes more power, I will have the SCR filter off the car later this week.( I can tell you from the hundreds of pulls I have done on these cars, its not going to make 20rwhp more with it removed) Green: Euro Spec tune Red: US spec |
04-06-2016, 06:04 PM | #17 |
Rep 241
I made 237 stock and 283 with jbd@100% on the dyno.
12-08-2017, 02:34 PM | #19 |
865
Rep 642
12-08-2017, 03:09 PM | #20 | |
Rep 4
p.s. i want to go EDC16 because of the future tuning for hybrid turbo, EDC17 cant read/write trough OBD |
12-08-2017, 06:20 PM | #21 | |
865
Rep 642
12-09-2017, 02:41 PM | #22 | |
Rep 4
How Much does it cost to ECU tune with Hybrid turbo ? Can you get me your contacts ? email or FB ? |
