Anyone have lots of experience with BMS CAN tool?
03-16-2016, 10:39 AM | #1 |
Rep 441
Hey guys,
When I bought my JBD, I got the BMS CAN tool as well, but never really utilized it for ALL that it could do. I was stock at the time and just using it to reset codes if I had my JBD set too high. However, now that Im out of warranty, I want to do some emissions bypassing...like EGR blocking plate and such and Im not quite clear on all of the messages this thing will clear automatically when its always plugged in (or manually). BMS no longer sells this device and will not support it at all due to emissions regulations (they may have gotten into trouble about it) Here is the relevant portion of the factory instruction manual that I am wondering about.... For your convenience the CT can be equipped to automatically delete certain codes when they go pendingThe main question I have...and I think I know the answer....will this automatically clear codes that are caused by the EGR block plate? But What else will it automatically clear? SCR related codes if I pull the fuse? I guess I need someone thats got a ton of experience using this thing and doing emissions bypassing... Thanks guys. |
03-16-2016, 12:03 PM | #2 | |
88
Rep 358
Because of the uncertainty I've been taking it off once a month or so, driving a few days with the SES on, and then checking the codes to see if anything other than the emissions codes was causing the SES. So far nothing. |
03-16-2016, 08:33 PM | #3 |
Rep 441
Thats good news
Well at least that helps. If it will definitely clear the EGR codes I can move right into ordering a block plate pronto and then get it all set up for not having to deal with that carbon shiz again.
You mentioned SCR codes....which ones do you think/know it clears? Currently I am getting intermittent level and temperature codes.... But what if I pull the fuse to the tank entirely like it says to do when you put on a flash? If it handles both of those....Im pretty much set for a bit. What about errors caused by throwing on a downpipe instead of the dpf? |
03-17-2016, 03:17 PM | #4 | |
Rep 441
03-17-2016, 09:51 PM | #5 | |
88
Rep 358
The way I understand it the code-suppression feature is really low risk. You're not actually coding anything, it's just clearing certain codes on the fly as they pop up. Before you gut your SCR or do anything irreversible I would set it up, pull the fuse, and see what happens. Like I said above, my only concern is missing a code that's not emissions related that could hurt the car if left uncorrected for too long, which is why I check it every now and then. Eventually I'll get a proper tune but for now this is working for me. |
