Methanol injection help
03-16-2016, 11:13 PM | #1 |
277
Rep 1,574
I have a meth kit that I installed and have been using it for a while but I have installed it by having a bottom in the center console to inject when desired. I want to have it inject under certain boost. What do I need to convert my system?
03-17-2016, 01:18 AM | #2 | |
Rep 700
A variable controller will be able to come on at a certain psi, stay on and progressively spray until a desired amount of psi is reached. |
03-17-2016, 05:27 AM | #3 |
Rep 934
or you can go mechanical and get a Hobbs switch, which you pre-set for a specific psi for the switch to close. which I have at the moment but I will upgrade to a progressive controller later.
03-17-2016, 10:16 AM | #4 | |
277
Rep 1,574
03-17-2016, 10:42 AM | #5 |
Rep 579
Here's a link to my water/meth install writeup - might give you some ideas:
Uber's 2-stage W/M install |
03-17-2016, 01:04 PM | #6 |
Rep 3,489
Drives: Montego Blue 335d
Im getting my meth kit installed this weekend HOPEFULLY
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
03-17-2016, 03:54 PM | #7 |
389
Rep 1,623
Easiest is to use a hobs switch. Or run a progressive controller that reads an actual boost signal, not voltage.
I tried using the MAF and MAP with no luck. I ended up running an AEM digital boost gauge with a 0-5v output to control my cheap HPC controller. |
03-17-2016, 04:25 PM | #8 |
Rep 1,442
I used a snow kit...it reads the pressure from the charge pipe (welded on). Make sure you watch your EGTs. Anything over 50% meth is going to ramp them up quickly. First stage kicks in at 18 psi second at 26 psi.
03-17-2016, 04:30 PM | #9 |
Rep 579
03-17-2016, 04:34 PM | #10 |
Rep 1,442
my boost maxs at 28 and I can tell from the controller that it is spraying and I can feel it for sure
03-17-2016, 04:55 PM | #12 |
389
Rep 1,623
03-17-2016, 04:57 PM | #13 |
389
Rep 1,623
You can use a 1/8 npt and tap the plastic elbow or manifold. No welding is required.
03-17-2016, 05:46 PM | #15 |
389
Rep 1,623
03-17-2016, 07:02 PM | #16 | |
Rep 1,442
03-17-2016, 07:14 PM | #17 |
277
Rep 1,574
03-17-2016, 07:18 PM | #18 |
389
Rep 1,623
Yes I run an AEM digital gauge. I use the AEM map sensor tapped into the manifold to feed the gauge.
Then, the gauge has a 0-5v output I run my WI off of. |
03-17-2016, 08:22 PM | #19 |
22
Rep 34
I run a Devils Own kit. You can pick up one of their progressive controllers for under $200.
http://www.alcohol-injection.com/en/...ontroller.html I am running up to 35psi boost and have the controller starting at 22psi maxing at 30 with a 1000cc nozzle. It works well for me. If I decide to go further with my car, (hybrid turbo) I would probably have to look at a better controller, but for what I have it works. |
03-17-2016, 09:38 PM | #20 | |
389
Rep 1,623
03-27-2016, 03:45 PM | #21 |
277
Rep 1,574
Another question for those who have their tank in the trunk. Which route are you using for running your hose. I ran mine through the the back seat to the kick panel trim into the dash but the back seat pinches it off when my fold downs are latched in.
03-27-2016, 06:32 PM | #22 |
389
Rep 1,623
I have a bulk head fitting in the truck floor. Tube goes from pump to bulkhead, from bulkhead to over the subframe on the driver side and then follows the fuel lines all the way to the engine compartment.
