Mis fuel (gasoline)
03-23-2016, 12:52 PM | #1 |
Rep 37
Mis fuel (gasoline)
So, I filled up with Chevron diesel, or so I thought. Apparently the suppliers driver filled the Stations diesel tank with gas. 150 miles later, no/go. BMW says change out EVERYTHING. The tab is already so high my insurance is considering totaling . This seems a little excessive . I do NOT want to lose this car. Has anyone else gone through this?
03-23-2016, 12:58 PM | #2 |
Rep 579
The only things really "needing" changed are the pumps and injectors. The lift pump might be OK. Tell them to pressure test it and keep it if good.
Engine oil needs "changed" as well. Should be taken for granted, but you never know... |
03-23-2016, 01:20 PM | #3 |
Rep 462
If it's anything like the tdi's, when they get gasoline in their systems, it puts tiny metal shavings through the fuel system. So that includes injectors, rail, hp pump, LP pump, lines and fuel tank. That would probably be over $10k as a wild guess
03-23-2016, 01:25 PM | #4 | |
389
Rep 1,623
I say total it and buy it back. |
03-23-2016, 01:30 PM | #5 |
Rep 579
Doing a piecemeal approach to save $ is an option that would include flushing the entire system while it's apart. But it's risky and could entail a complete new everything anyway. You just don't know what you have on you hands with this scenario until it's all taken apart, inspected and tested.
03-23-2016, 01:36 PM | #6 |
Rep 37
This is what my diesel guy thought as well, until he talked to BMW. They told him the clean diesel system requires much more. Damn
03-23-2016, 01:41 PM | #7 | |
Rep 37
03-23-2016, 01:42 PM | #8 |
Rep 579
It's fairly common industry practice to replace the entire fuel system lock, stock and barrel after catastrophic injection pump failure in a commonrail system. It's the only way to guarantee a good outcome. Other options really just depend on how money factors into it.
03-23-2016, 01:46 PM | #9 | |
Rep 37
03-23-2016, 01:48 PM | #10 | |
Rep 37
03-23-2016, 01:49 PM | #11 |
Rep 237
This should be covered by the station owner's insurance and the delivery company. You should not have to pay any out of pocket expenses to repair this. I am sure you are not the only diesel vehicle to have this problem. If they do not offer to cover it, get a lawyer and take them to small claims court if it is under $10k.
03-23-2016, 02:22 PM | #12 | |
Rep 37
03-23-2016, 02:24 PM | #13 | |
Rep 2,210
Since they filled what *was* the diesel tank in the ground it was likely a mixture of diesel and gas, if the tank was fairly full when they filled it and the tank in the car wasnt completely empty when filled it could still be a fairly high % diesel mix in the tank. Check out the video below starting at 4:00, its obviously an old style diesel motor but it makes the point that a diesel can actually run on gas and survive for a bit, so obviously the higher the diesel portion of the mix the further youll make it. Unfortunately, making it further isnt necessarily a good thing. Last edited by Hoooper; 03-23-2016 at 02:36 PM.. |
03-23-2016, 02:38 PM | #14 | |
Rep 2,615
03-23-2016, 02:50 PM | #16 |
Rep 529
Which makes it even worse. What a beautiful car the E90 m-sport is in Le Mans Blue.
Good luck with getting everything sorted.
2011 335d Deep Sea Blue on Beige (stock except for the cheap ass wheels from PO)
2010 328i Tasman Green on Saddle (stock) |
03-23-2016, 03:03 PM | #17 |
Rep 3,555
Never heard of this before(gas put into diesel station tank). That said, this is my first diesel. Veteran's of diesel might have read this type of thing on other boards. This appears to be first time here. I've only been around here since Nov 2011 though.
Seems to me that the station owner could turn around and blame delivery truck. The trucks aren't necessarily (Chevron in this case) employees of same company. It could be trucker from local terminal. Only difference from load to load (Chevron versus say Shell) is the additive package that is added into tanker truck. So here is a weird twist to ponder. Was the mistake at the terminal or at the station? Did the tanker driver mean to load diesel or gasoline at the terminal OR did the tanker driver consciously put gasoline in at terminal and then screwed the pooch and didn't put it into the gasoline tank at the station? I have a close friend that has worked for Chevron for better than 20 years and is connected to fuels provided to stations. I'm curious if anti-misfueling hardware is used at terminals and tankers like we have on station pump nozzles and "little door" on our cars. It would mean that a tanker is a diesel only or a gasoline only. I'm betting that the "put it in at the station" part is generic diameters though. I will ask my friend. |
03-23-2016, 04:17 PM | #18 |
Rep 700
When I worked for VW there were several occasions porters would go fill up diesel vehicles with gas by mistake. Granted these cars never went 150 miles before dying. A technician would gain access to the fuel tank and use an electric pump to pump out as much gasoline as possible, put about 5-10 gallons of diesel back in, and replace the fuel filter. They would start after that, and they would leave them running outside for a while. The service manager or a technician would go top it off with more diesel and the sales people would put them right back on the sales lot... Those diesels weren't as sophisticated as a 335d though.
03-23-2016, 04:27 PM | #19 |
Rep 215
Drives: E39 M5, F15 35d
Ouch OP, sorry to hear Shitty luck I guess, but hopefully everything gets fixed by insurance and you're not out any $ in the end.
03-23-2016, 04:30 PM | #20 |
Rep 6,196
When I worked in Northern Canada, we would always dump a couple litres of gas in when filling up the diesels to prevent the fuel from jelling. Never seemed to hurt them.
03-23-2016, 06:56 PM | #21 |
277
Rep 1,572
And I'm assuming this was a huge rig? Just like people do oil changes in the Artic with the engine running?
