Carly Fault Codes
03-23-2016, 11:23 PM | #4 | |
88
Rep 358
I went through I think 4 injectors and about 6 trips to back to the dealer after my carbon cleaning before they finally got it right and I stopped getting those zero mass adaptation and cylinder roughness errors. There is a very specific process that they need to run through to get the injector adaptations set correctly that in my case involved five 10 mile calibration trips with the car allowed to go to sleep (locked for one hour) between drives, as well as a series of chants and incantations in between. (I'm serious except for the chants and incantations bit). In my case they actually had to run this process twice to get it to "take." Maybe one of the trips was only 9.8 miles the first time they tried, who knows. I've posted about my injector issues so if you go back and search through those and then go into your dealer as educated as possible hopefully you can avoid having the same issues I had. I would try to convince them to redo the calibration using whatever PUMA says is the latest and greatest method before just throwing new injectors at the problem. Good luck. I hope you have some remaining warranty. |
03-23-2016, 11:38 PM | #5 |
Rep 266
^^ what he said ^^ if cbu clean has been done you need your ECU updated to the latest version and your injectors properly calibrated by the dealer.
03-24-2016, 01:28 AM | #6 | |
Rep 130
03-24-2016, 08:16 AM | #7 |
Miami Diesel
Rep 20
I love this car, but it sure is a pain in the ass to be at the dealer every month.
Isn't an injector calibration is more likely to shop up immediately after CBU cleaning rather than 6 months later? Strange that my repair receipt doesn't actually mention anything about carbon... Car was at dealer for 2 weeks back in August.. |
03-24-2016, 01:14 PM | #9 |
NY BRAVEST
47
Rep 231
Can't ISTA D with the icom a+b+c do all the calibrations? And reset values. I do agree these cars are way to computer driven with way too many sensors.
