03-28-2016, 01:19 PM | #1 |
Rep 269
228i on H&R only dropped 1/2"
So, I installed H&R springs on my 228i this weekend. I have an M Sport, so I was expecting 1" front and .8" rear per H&R's website. What I've gotten, however, is right around 1/2" all the way around, maybe a little more in the rear. Measured from fender to center of the roundel on the wheel I went from 13.5" to 13" on the fronts and 13.5" to about 12.875" in the rear.
As far as I know, I installed everything correctly. Everything with the seats/perches was lined up nicely and I loaded up the suspension to retorque everything. I do know that the springs are the same as the M235i springs, so I'm not totally surprised they lower less when installed on a 228i, but half the advertised height? Any 228i owners with H&R springs willing to measure their front/rear ride height from fender to wheel center and see if I've got an issue? |
03-28-2016, 02:48 PM | #3 |
Rep 178
yup. need to let it settle.
do you have passengers frequently in your car? if so, it may only take a few days to settle. i rarely do, so i usually give it a good week or so.
-roger
Current: '15 F22 EB 228i | M Sport | 6MT | Dinan | Rotiform | 35% tint | CF side mirrors Gone: '11 B8 A4 | '08 Infiniti G37 Coupe 6MT | '04 E46 M3 6MT |
03-28-2016, 03:40 PM | #4 |
Rep 269
I always knew things settled for a while, but never figured it would settle nearly half an inch. Seems a bit much to me, but I guess I'll find out soon enough.
And no, I rarely have passengers, but I did take a 200 mile round trip with my wife the day after I finished. No change before/after the ride. |
03-28-2016, 09:10 PM | #5 |
Rep 980
Of course nobody here would ever suggest that your wife sitting in it would have ANY effect on lowering the car.
If you want the car to settle in a hurry, I am willing to offer you the services of my mother-in-law.
2015 BMW 228i M Sport w/Track Handling Package DAP | Lighting | Premium | Tech DINANTRONICS Performance Tuner Stage 1 | DINAN Shockware | DINAN Free Flow Exhaust | DINAN Performance Spring Set + Ride Quality and Handling Kit |
Anthony235715.00 |
03-28-2016, 09:46 PM | #7 |
Rep 566
Two things to keep in mind: 1) those spring are not designed specifically for 228i (228i is not even listed in their certificate), different loads, 2) when used on a vehicle with M-Sport suspension they lower about 15 mm less than what you'd expect with a standard suspension (which is mentioned in the certificate).
03-28-2016, 10:44 PM | #8 |
Rep 178
OH no you didn't!
-roger
03-29-2016, 09:28 AM | #9 | ||
Rep 269
These are the same springs that lower the M235i by 1" front and rear, so I don't really see how it's possible the 228i would be lowered the same (specially in front with a 50% larger engine). I just want to be sure I have the right parts and didn't screw up the install causing the discrepancy in ride height. |
04-12-2016, 08:50 AM | #10 |
Rep 269
Just checking back in. It's been a couple of weeks now and the ride height is exactly the same. Not the slightest amount of settle. I've come to be OK with the height it's at I guess, but I still wonder what set of circumstances lead to the unexpected drop amount.
Can anyone with my trim level (228i M Sport) and H&R springs measure their height from fender to wheel center cap? Thanks! |
onehungevo63.50 |
