TPMS system disability?
03-28-2016, 05:05 PM | #1 |
Rep 244
I've got a bad sensor or module somewhere in the car, rather just do away with the whole deal.
With my 2010 TDI I was able to go right into vag com and code out the TPMS system/low air light.. Anyway to do this on the ol 335d fellas? |
03-28-2016, 06:41 PM | #2 |
Rep 1,192
I did this for my winter tires that have no sensors. It is a bit involved though. You have to disconnect the receiver unit in the right rear wheel well. Then code out the option from the Vehicle order and recode a few modules with NCSexpert. Here is a description from the Coding section:
- Remove Connector to TPMS - Remove 2VB from VO - Code CAS with VO (FA_write) - Recode DSC, CAPPL/CIC, and Kombi for the new VO 2MULF: ISPEECH_RDC nicht_aktiv CIC module: RPA_CIC aktiv RDC nicht_aktiv RDC_SAFETY nicht_aktiv KOMBI module: RDC_ALIVE nicht_aktiv MMI_ENA_RPA_RDC aktiv RDC_VERBAUT nicht_aktiv K4113_C_ZEIT_3 wert_02 DSC_MIT_RPA_CC aktiv RDC_DISP_SWITCH nicht_aktiv DSC module: C0F_BBV_KORR_HA wert_01 wert_04 C0F_BBV_KORR_VA wert_04 C0F_RPA wert_00 |
