Motor Mount Replacement
03-28-2016, 05:29 PM | #1 |
Rep 21
Quick summary: my dealer is telling me I need new motor mounts and that they are not covered under CPO - seems ridiculous that a motor mount on a car like this (highly sophisticated mounts) wouldn't be covered.
Long story: If I accelerate through a left hand corner (only lefts, not rights, only acceleration, not braking or coasting) then the car makes a very nasty and loud grinding sound from the right side. I'm pretty confident (and so is the excellent 3rd party mechanic I use) that it's the inner race on the front right wheel bearing. My dealer put a sound diagnostic kit on the car and diagnosed the steering box, which they replaced under warranty, but of course that wasn't the issue, now they are telling me it's the motor mount and they want $800 to replace it. Recommendations? Anyone know: (a) how to really know if the motor mount is covered under CPO or not? (b) if I have any recourse if they replace the motor mount and the grinding sound still isn't gone - which I very much doubt it would be? Thanks. Last edited by maddog2020; 03-28-2016 at 08:09 PM.. |
03-28-2016, 06:11 PM | #2 |
Rep 57
I'm interested in this topic as I'm having the same issue and thought it was the inner lining of the fender of the front pass side wheel well. I trimmed the liner, but it's still loud as ever. Super annoying!
03-28-2016, 06:28 PM | #3 |
Rep 21
Right, it really sounds like something making contact in there. Only when you give it a bit of throttle in a left turn, correct? So you know, it's been getting worse in my car, happening more frequently, and the grinding much louder.
03-28-2016, 09:11 PM | #4 |
Oil Burner
21
Rep 119
Drives: 2009 335d Barbera Red Metallic
I have taken out the passenger side motor mount, as have many others. The procedure is described briefly in a thread by Mik325tds. It is not too hard if you have jack stands and the right tools. Probably you can remove the driver side mount in the same way.
What I discovered when removing it (and accidentally damaging it or finding damage), is that the motor mount is vacuum controlled and has an inflatable bladder inside a plastic cover There are many mounts sold that will fit, but the vacuum one is over $200 for the part. In my case the plastic casing was cracked and I repaired it and re-installed. I recommend you read the DPF removal threads on how to remove the passenger side motor mount. , Be sure you really have to replace, before doing it!
2009 335d Barbera Red Metallic; Mods: BPC tuned, Bohl Diesel Performance, Laser Veil, BelTronics Pro 500
03-28-2016, 10:24 PM | #5 | |
Rep 61
03-28-2016, 11:13 PM | #6 |
Rep 296
Drives: E90 335d | i3 REx
I had an issue with one engine mount and it wasn't covered as it was "wear and tear" so no CPO.
It manifested itself when idling and at low speeds. Went away at higher speeds. Ended up buying new engine mounts (both sides) from getBMWparts and having a local Indy change them out for like $150.
2011 E90 335d M Sport | KW V3 | M3 Bits (arms/bushings/sways) | JBD | Apex ARC-8 w/PSS
2015 i3 REx | Solar Orange | Tera World | Tech |
03-29-2016, 12:42 AM | #7 |
Rep 2,615
OP. why don't you test your vacuum controlled mounts hold vacuum. Easy to do if you have jack/stands, 8mm socket wrench and a hand vacuum pump with a gauge. Or you can do it from under the hood if you know where the EUV for the mounts is and disconnect there at the outlet, will test both mounts and lines to them.
03-29-2016, 07:13 AM | #8 |
Rep 128
I can verify that my motor mounts were NOT covered under CPO warranty. They are considered a "wear" item. As relemasi said it should be obvious if your mounts are bad when idling/in park. I had A LOT of vibration that went away once the mounts were replaced. Showing up only in a turn definitely sounds like something else to me. Good luck convincing the dealer of that.
03-29-2016, 07:43 AM | #9 |
Rep 182
I also have a noise when accelerating in left hand turns. Almost sounds like a rubbing, I thought maybe it was the shocks getting to the bump stops and making some horrid noise. But come to think of it, it's only left turns.
03-29-2016, 08:38 AM | #10 | |
Rep 1,288
Hard acceleration combined with a hard left hand turn will instantly trigger the traction control. The ABS module that contains all the pumps / solenoids is located in the right hand side of the engine bay somewhere and easily heard when it is modulating. |
03-29-2016, 10:15 AM | #11 | |
Rep 21
03-29-2016, 10:25 AM | #12 | |
Rep 21
I'm extremely disappointed in the CPO warranty. So far only one thing has been covered under the warranty (the DEF active tank replacement). I really enjoy driving this car, but it's starting to turn into a serious money pit. The basic maintenance costs are so high with the need for fuel filters and all sorts of other stuff that are only required on diesel cars. This is my 4th BMW, and sadly will be my last. Time to sell it and buy a Ford. I must be getting old. |
03-29-2016, 10:30 AM | #13 | |
Rep 21
03-29-2016, 10:46 AM | #14 |
Rep 40
AHHHHHHH
I complained about this EXACT noise, it's the exhaust hitting the body. When I complained in warranty sub 50k they said the DP to cat bolts were "loose". But the problem was still there on the hard left accelerations. I will have to see if I can get them covered in CPO because it's now worse. I get heavy vibrations right over bumps as the suspension compresses. Feel like the motor is bottoming out on the mounts. Maybe when I bring it in for the airbag recall |
03-29-2016, 10:38 PM | #16 |
Rep 40
Well I did some additional digging and turns out it's not the exhaust hitting the body.
The motor mount bracket is actually contacting the motor mount housing. I snapped a pic for those that are interested in what's causing the noise. Dont mind the oil leak that the dealer says isn't there. Last edited by peteyypab; 03-29-2016 at 10:49 PM.. Reason: Fixed pic link |
03-30-2016, 05:00 AM | #18 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
It doesn't look like oil on the mount, looks like soot. Not unusual to have had soot leak, but if your leaking soot, it's probably worth it to find it.
03-30-2016, 10:24 AM | #20 |
Rep 21
I'm having the motor mounts replaced tomorrow, I'm actually fairly confident after doing some more research that (despite my original post) it is the motor mount. Given that this isn't covered under CPO (what a joke), I'm having it done at a local indy shop, not the stealer.
The reason I'm more confident about the motor mount is that I tried using manual gear selection to keep the revs at different levels while taking the same corner at the same speed and acceleration, and the frequency of the "grinding" appears to correlate with engine revs. I'll post an update tomorrow if the replacement mount fixes things. Ian |
03-30-2016, 10:40 AM | #21 | |
Rep 579
Stealers Strike Again
That is of course, if you have the time to be a vindictive customer from Hell like me. |
03-30-2016, 10:55 AM | #22 |
Rep 128
Well maybe I'm not a vindictive customer from hell but I called 3 local dealerships that all told me motor mounts are considered wear items and not included in CPO. Good luck.
