New MAP sensor. Still getting Boost pressure sensor signal interruption code
03-30-2016, 09:07 AM | #1 |
393
Rep 1,578
Boost pressure sensor signal interruption oKurzschluss to earth Code: 003F01. That is my only code. It comes back after a couple of days after I clear it.
It's an 09 X5 35d w/ 44k miles. I replaced the MAP sensor last month. It hesitates while accelerating gently. In addition to the sensor I have changed all vacuum hose, actuators, and the red boost hose. I pulled the manifold last week and there was not a ton of CBU. Any ideas what I should check next? Could Rheingold help? The sensor wires directly to the ECMs so I don't think there is a ground connection point to check. I suppose there is a chance the new sensor is also bad. That is a easy $70 check. I checked ground with my volt meter and it shows as good even when I wiggle the pigtail of wire around. Thanks |
03-31-2016, 09:50 PM | #4 |
Rep 3,541
Smassey, that looks like the older style of hi press EGR valve. Reason I recognize it is the inward protruding boss on the left. I had the recall done and the EGR isn't made like this anymore. I got another used EGR valve so that I could machine out its throat and this one looked same as yours prior to me hacking it into a smooth throat. I will double check.
That said, X5 hi press valve could be different and similar in design to obsolete 335d valve. Did you have the recall work done? |
04-01-2016, 10:14 AM | #5 | |
393
Rep 1,578
04-01-2016, 02:59 PM | #6 |
Rep 3,541
I'm sorry. I messed up. Your valve is the updated one. I have a picture of my updated valve. It matches the #1 in your attached illustration. Indeed, your #2 was what I hacked up for my "straight through" valve. Second pic is a side by side of old "throat cleared" valve and updated one. And sorry again for pulling off track. My bad. I don't have picture of old valve before surgery began.
