First Emissions test.....?'s
03-31-2016, 07:46 PM | #1 |
Rep 804
Car is a 2009 335i FBO..... with catless downpipes
do i need anything to pass its first emissions test or can i just set up an appointment and hope for the best. do i keep it flashed with the MHD 94 octane map or flash back to stock? any insight would be appreciated thanks
E90 LCI M-sport/ 6AT/ LSD/ FBO+
04-01-2016, 10:02 AM | #2 |
Rep 241
I think the emission test now doesn't really check the "emission gas" anymore.
I remember when I was with my e46, they just plug in the code checker and check if I have any error codes and that's it. |
04-01-2016, 11:27 AM | #3 |
Rep 804
if its true that we are allowed 1 "incomplete" on the test then i should be okay taking it in as is since my MHD only reads the catalyst as being "incomplete"
04-04-2016, 11:19 AM | #5 |
Rep 1
https://www.ontario.ca/page/drive-cl...ts-and-repairs
You will definitely need to fix the O2 sensor. Do you have access to any code readers (Torque app + BT OBD dongle)? |
05-09-2016, 04:22 PM | #7 |
Rep 196
Drives: 2009 335xi coupe
when I did mine few weeks ago all I did was flash back to stock and drove the car about 40km never went over 3k rpm cats showed ready only evap was off still passed and I don't have my primary cats didn't use dp fix either
Motiv tuned l VRSF DP l VRSF 7" IC l ER CP l hexon rr600 l mmp inlets/outlets l KW V1 l Fuel-It! Stage 2 l bmw performance exhaust l
05-09-2016, 05:06 PM | #8 |
Rep 4,668
Drives: BMW
This is the only thing that doesn't "pass" for me the last two times I've had it tested - always reads "not ready", I guess because it's not warmed up or I haven't driven it long enough pre-test. But if that's the only problem, should be no problem passing.
05-09-2016, 06:38 PM | #9 |
Rep 804
passed yesterday. flashed MHD to stage 0 and installed wedge dp fix. Evap was the only thing not ready but still passed.:thump:
time to turn it back up again
06-12-2016, 10:03 PM | #12 |
Rep 214
Drives: 2009 BMW 335i Coupe
I have a 2009 335i with catless dp with the MHD tune and this is the readout from the MHD app:
View post on imgur.com There's 1 incomplete and 4 "not avails" which I'm assuming is because they aren't valid for the car. Would this pass emissions? |
06-13-2016, 08:27 AM | #13 | |
Rep 14
correct, the "not available" means those tests are not valid for the car. |
06-13-2016, 08:34 PM | #14 |
Rep 214
06-15-2016, 08:44 PM | #15 |
Rep 113
I did mine 2 weeks ago with MHD installed. I had stock exhaust at the time but because MHD was installed it showed cats not ready. Still passed.
07-05-2016, 01:25 AM | #16 |
Rep 214
Reporting back. Did my emissions test with downpipes and MHD tune and passed without a dp fix. Yay!
10-11-2016, 01:09 PM | #17 | |
Rep 267
Also, what kind of dp do you have and where did you buy it? Still undecided. lol Thanks! |
10-11-2016, 07:36 PM | #18 | |
Rep 214
If I was you I'd wait for 2 reasons: 1) Emissions due soon, might as well be safe and get the easy pass then install catless down pipes. 2) Black Friday is almost here and most vendors on here have sales on these parts. |
