04-02-2016, 02:59 PM | #1 |
Rep 542
To all Coders- Get your hands on an M2 and code away!
Getting my E90 coded was one of the most useful "mods" I had done to my car...
I know the M2 community may be smaller in volume, but we will not lack enthusiasm.. -c
2016 BMW M2/LBB/6MT/Exec Pkg
2009 Acura MDX-stock 2008 Acura RDX-stock 2005 Honda S2000-mostly stock 1994 Nissan 300ZX Twin Turbo-barely stock |
04-04-2016, 07:09 PM | #2 |
655
Rep 1,922
Drives: 2011 e91
I'm really only interested in useful things, like the fake exhaust in the cabin. That has to come off.
Most of the codes should be standard 2er codes.
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
04-06-2016, 05:21 AM | #3 |
Rep 2,856
Drives: BMW M2 CSL Turbomeister
Can we do this ourselves or is it paying for a program to install on your laptop and buying a ODB?
I think pulling the ASD cable from my HK ampilifier will be easier :P MR |
04-07-2016, 07:29 PM | #4 |
234
Rep 350
Has long as you have a laptop capable of running Windows on it (WinXP or 7 are preferred I believe) then you can do it yourself. In the 2Addicts forums you can post asking for the necessary software and you'll probably get a PM pretty quick with links to download ESys and the latest psdzdata. Then it's a matter of buying a cable off ebay or the like or you may be able to make yourself one.
http://www.2addicts.com/forums/showthread.php?t=997749 is probably the best place to start. I would expect the M2 is going to be rather similar to the other F22/23s. I've got ESys running on a Win7 VM on my MacBook Air and have used it to code my 228i, hopefully will do the same with my M2 next year |
carlos80815.00 |
04-10-2016, 08:09 AM | #5 | |
Rep 542
04-10-2016, 09:04 AM | #6 |
Da Baus
283
Rep 259
There are also many coders in the NE Tri-state area that you can travel to for a reasonable price. All of whom have plenty of experience with F platform. bimmerscoding.com is a sponsor here
http://f87.bimmerpost.com/forums/sho...d.php?t=965895
M2 LBB/6MT/VFstg2/V1 stealth/JRC valve delete/Dinan/
Fabspeed/Wagner/ER/Eibach/UCP/RTD RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID E46 330ci --> S54 M3 xplant vzv 3bananas (retired) |
04-18-2016, 08:17 AM | #8 | |
Rep 542
-c
Dav3948.50 |
04-18-2016, 08:04 PM | #9 |
Rep 3,888
04-18-2016, 10:19 PM | #11 |
Rep 3,888
04-18-2016, 10:24 PM | #12 |
Rep 836
04-18-2016, 10:28 PM | #13 |
Rep 3,888
04-18-2016, 10:29 PM | #14 | |
Rep 836
05-31-2016, 09:12 PM | #15 |
757
Rep 1,835
Drives: 2020 X4M CS
F series works off a TCIP system, rather than D+KAN....No OBDII to ethernet cable ans e-sys, and data or know how to extract and modify existing data...
Im a beginner...But i had a pro coder try to code out ASD and he made it clear you cant...U can change the sound or make it a little queiter but not turn it off or down enough. Ive read about just unplugging the ASD amp on HK systems...That works on some cars, not M2...Trust me I tried. Its integrated and the sound in is fiber opt.... Technik harness is only option.
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
06-05-2016, 09:14 AM | #16 |
Rep 607
Drives: 2019 BMW M2 Competition
I just coded my M2. I am on that 2addicts thread quite a bit. I had an M235i before. Everything coded is pretty similar to F22.
Couple things I coded -
Also - apparently you can disable ASD via coding - parameter = Model Range in the ASD ECU change from F87 to F020/F021 Not sure if this works or not. I guess I cannot hear, because I never notice the ASD. Also like to drive with the windows down. And that is correct. F series communicate via TCP/IP over OBD to RJ45. I also have a DKAN cable, I have coded numerous E series as well. Completely different. Requires different software and cable.
2019 F87 M2C, Long Beach Blue, Exec, 6MT 2016 F87 M2 - Sold 9/2018 2014 F22 M235i - Sold 5/2016. |
06-05-2016, 10:23 AM | #17 |
Da Baus
283
Rep 259
Anyone have success in getting the dash backlighting to remain on during the day?
06-05-2016, 10:49 AM | #18 | |
Rep 542
-c
06-05-2016, 11:35 PM | #20 | |
Rep 69
other codes
Any idea if any of if these options exist yet? I'd love to see a master list. There are probably other things that I haven't even thought of that I'd select. Does anyone know how long it usually takes the coding community to get a good handle on a new model? thanks all |
06-06-2016, 10:37 AM | #21 |
Rep 607
Yes I would assume. Obviously this is hours of usage.
DRLs run at 100%, so this is only halos/lights at night. So depends how much you use that part. I dont drive at night.... that much in this car.
06-06-2016, 10:53 AM | #22 | |
Rep 607
what is auto blip? You can turn music off when you open door. You can code to unlock door at shutoff - only requires one pull instead of 2 Cannot change start mode. No one figured that out yet. I think you can do comfort or eco. So no sport yet
