Replace hose with?
04-08-2016, 07:36 PM | #1 |
Rep 441
Replace hose with?
I know Ive seen pictures of this POS brittle hose somewhere... Is everyone replacing it with radiator hose or something? What are we thinking here?
https://goo.gl/photos/NzgM2nssKEMcBm9C6 Last edited by OmahaDZL; 04-09-2016 at 10:37 PM.. |
04-08-2016, 07:59 PM | #3 |
Rep 441
Kinda what I was thinking...no reason for it to be that thin of plastic. There isnt an aftermarket version of this out there right? just a normal hose...correct? Is this in a place that it needs to be silicone?
04-08-2016, 08:20 PM | #4 |
Rep 291
Actually i just remembered, i have mine somewhere in garage, if you need it
This is the hose which needs to be removed in order to install oil catch can. So i believe a lot of people on the forum have them around This area is generally hot side of the engine so silicone probably will work better, anyway rubber will last many years, just make sure it is oil resistant hose as it is an oil breather. But having it broken i would say go for catch can install, i truly believe it is a needed mod. |
04-08-2016, 08:27 PM | #6 |
Rep 291
04-08-2016, 09:22 PM | #7 | |
NY BRAVEST
47
Rep 231
04-08-2016, 09:43 PM | #8 |
144
Rep 316
Push lok hydraulic hose would be about the best oil resistant option, happen to able to measure the two od's? I'll check it against some pieces of hose in the shop. Silicone will work for awhile, but it will eventually soften and bleed.
04-09-2016, 01:30 PM | #9 | ||
Rep 441
04-09-2016, 01:31 PM | #10 | |
Rep 441
04-09-2016, 02:30 PM | #11 |
Rep 432
I replaced mine with some silicone hose, but its seeping out around the ends of the hose now. I'm thinking of going with the OEM piece again, unless that Push Lok hose would work?
Compliments of "135i_vs_" from the catch can thread: Last edited by Owen81; 04-09-2016 at 02:49 PM.. |
04-09-2016, 10:36 PM | #12 |
Rep 441
Thank you Owen81....that was what i needed to know.....I went back a few pages and found that thread...hopefully I get the answers I need soon so I can get parts in the mail...
04-09-2016, 10:50 PM | #13 |
NY BRAVEST
47
Rep 231
04-10-2016, 07:52 AM | #16 |
Rep 3,556
FYI, that OEM ribbed hose can only be purchased as part of an assy with top connector that snaps onto plastic duct as well as small harness. I recall getting whole assy for $63 from Husker. I had broke the ribbed hose and wanted to have it if I go back to OEM setup. I put pic of that assy in earlier thread.
EDIT: added picture here. Last edited by BB_cuda; 04-10-2016 at 08:09 AM.. |
04-10-2016, 12:48 PM | #17 |
55
Rep 336
Drives: 2010 BMW 335d
Garage List 1984 Dodge Ramcharg ... [0.00]
1988 Ford Bronco 351 [0.00] 2002 BMW e39 540i S ... [0.00] 2010 BMW 335d [0.00] 1997 Husaberg FC600 [0.00] 2010 X5 35d [0.00] 2015 Can-Am Outland ... [0.00] 2004 Ford F350 Supe ... [0.00] 2014 Ford Edge (Com ... [0.00] 2014 John Deere D130 [0.00] 2010 John Deere JS46 [0.00] |
Pretty fragile hose. Last year all I did was look at it and it just split in 2. Installed some rubber hose from there to the valve cover to keep driving it until the new part came in. New assembly still sitting in a box as my d has been running fine and not leaking any residual spooge 8 months later
04-10-2016, 12:58 PM | #18 | |
Rep 441
Please look at that thread and let this one die. |
