04-09-2016, 07:43 PM | #3 |
Rep 146
It's not bad. It does not have eq control only bass/treble so your limited on adjustments. I find fm and satellite radio to sound poor. Far to much compression in the satellite radio stream to sound good to my ears. I find the Amazon music app to stream some of the best quality sound and when streaming through that app (or similar) it sounds good.
Of course, wether you think it sounds good or not will depend on your tastes and previous experiences.. |
04-09-2016, 09:37 PM | #4 |
Rep 2,148
Drives: F87 M2 BSM MT
Its the same Harman kardon system that's in the M cars and optional on the other F series. I have this system on my current car and I do believe it has an EQ. I'll go take a pic of it later.
04-09-2016, 10:39 PM | #5 | |
Rep 146
For this car, I am not going crazy with multiple amps and a separate sub. Leaving it stock for the foreseeable future.. |
04-09-2016, 10:57 PM | #6 | |
Rep 2,148
04-09-2016, 11:07 PM | #8 | |
Rep 3,888
M2 5 x 26mm metal-matrix dome tweeters in the dashboard, front and rear 2 x 217mm woofers (central bass) below the front seats 5 x 100mm ALumaprene midrange speakers in the dashboard, front and rear Harman Kardon DSP amplifier in Class-D technology with 360-watt total output M3 and M4 7 x 26mm metal-matrix dome tweeters in the dashboard, front, side and rear 2 x 217mm woofers (central bass) below the front seats 7 x 100mm ALumaprene midrange speakers in the dashboard, front, side and rear Harman Kardon Logic 7® DSP amplifier in Class-D technology with a total output of 600 watts Last edited by zenmaster; 04-09-2016 at 11:46 PM.. |
04-09-2016, 11:16 PM | #9 | |
Rep 2,148
04-09-2016, 11:34 PM | #10 |
698
Rep 1,514
I know this may be a silly question but do you definitely have the HK stereo fitted? Here in Oz the Pure version of the M2 comes with the HiFi system which may not have the eq control & the Harmon Kardon is only available in the top spec model.
04-09-2016, 11:40 PM | #11 |
Rep 3,888
The M2 only 10% less passenger space than then M3 (90 vs 99 ft^3), but 25% less speakers (12 vs 16).
However, the M4 also has identical interior volume to the M2 but same number of speakers as the M3. |
04-09-2016, 11:40 PM | #12 | |
Rep 2,148
Executive package Manual/DCT Pick 1 of 4 colours
04-09-2016, 11:45 PM | #13 |
698
Rep 1,514
04-09-2016, 11:48 PM | #14 |
Rep 3,888
13
04-10-2016, 12:58 AM | #16 |
Rep 2,148
I see on bmwusa.com the M3 lists 600w but M4 list 360w can you confirm if this is accurate?
04-10-2016, 03:04 AM | #17 |
Rep 8,162
Both have 600 W.
04-10-2016, 03:07 AM | #18 | |
Rep 8,162
04-10-2016, 03:14 AM | #19 |
Rep 146
04-10-2016, 03:50 AM | #20 | |
Rep 8,162
mind = blown
04-10-2016, 11:14 AM | #21 |
132
Rep 394
The M2 HK does not sound quite as good as the 3 series HK. It's still very enjoyable, but ever so slightly less impressive. So just turn it off and listen to the exhaust instead. Sploosh.
04-10-2016, 11:42 AM | #22 | |
Rep 8,162
