diesel fuel priming
04-11-2016, 12:50 PM | #1 |
Rep 583
diesel fuel priming
I bought a non-running 335d a few weeks ago.
Found that the issue was fuel delivery. The low pressure pump, one underneath the rear passenger seat runs when directly wired to 12v. The connector going into the pump receives only 9-9.2v when unlocking the car/key in ignition. With this voltage, the pump doesn't seem to activate. From what I found online, pumps in the 328/335i cars should be reading be around 10v. Does anyone know what the normal voltage is at the low pressure pump plug/connector for the 335d? The fuel pump controller/module appears to be the same for both i and d models so I'd assume the module may have gone bad... However, even manually priming the low pressure pump with the battery for a few minutes, the car still failed to start. |
04-11-2016, 11:56 PM | #3 | |
Rep 2,210
If you got the lift pump to run and it still didn't start, have you checked the rail pressure during cranking? |
04-13-2016, 02:40 PM | #4 | ||
Rep 583
04-13-2016, 03:00 PM | #5 |
Rep 3,553
You better go read wrecker335d's thread. Something was up with the ECU not communicating with his pump controller module. He had changed both the lifting pump and controller and still no start.
http://www.e90post.com/forums/showth...1221553&page=2 see post #36. I'm not saying it is this for certain. I am saying wrecker spent lots of parts money and it ended up being this. I had thought I bricked my pump but thank goodness nope. |
04-13-2016, 04:05 PM | #6 | |
Rep 2,210
04-13-2016, 05:09 PM | #7 |
Rep 3,553
I didn't see voltage come out of pump module until I actually tried to crank. With ignition on only, no voltage at the pump pins. Yozh has a safer way to measure this as he can check without disconnecting the fuel pump. He installed blade terminals into the harness that connects to the pump's pins. I would minimize cranking with no fuel going to the HPFP.
Hooper commands his low press pump using bavtech cable. This is another safe way of checking pump without abusing the HPFP (if it isn't getting fuel). Good luck |
04-15-2016, 08:08 AM | #8 | |
Rep 583
Anyhow, there's barely any fuel coming out of the HPFP when cranked. Pressure seems to be good into HPFP. I have a re-manufactured HPFP on order (only $234!?). |
04-15-2016, 12:25 PM | #9 |
Rep 296
Drives: E90 335d | i3 REx
Off Topic
Just wanted to say that threads like these with such helpful responses from expert members is a major reason why I plan to keep the D past CPO warranty, even in CA.
Here's to all who have given their time and knowledge with the expectation of nothing in return.
2011 E90 335d M Sport | KW V3 | M3 Bits (arms/bushings/sways) | JBD | Apex ARC-8 w/PSS
2015 i3 REx | Solar Orange | Tera World | Tech |
