What is the best tool to monitor what the EGR is doing?
04-11-2016, 05:53 PM | #1 |
396
Rep 1,578
I have an intermittent hesitation under mild boost that I think is related to the EGR. I have Carly and Rheingold but I am not sure how to monitor the live data related to the EGRs (I have an E70 with 2 EGRs).
Thanks in advance |
04-11-2016, 07:25 PM | #3 |
Rep 196
Those tools will not help much if no faults are being set.
There are logging tools out there which do require a high degree of DDE knowledge to install, configure, and analyze the results. If you suspect EGR- just unplug the HFM - this disables it and sets a fault of course, but is the symptom gone? I'd check the turbocharger vacuum system control if this test has no effect. |
04-12-2016, 06:05 AM | #5 |
Rep 151
Hey there, I'm not 100% sure but think the EGR valve is closed when you have the car under load, as in not not stationary. If the valve is gunked up enough perhaps it is not opening and closing fully, that'd have to be pretty bad build up though.
Maybe another thing you could check it what rpm approximately your hesitation keeps happening at because the three moving parts on the turbo not working smoothly can all stop the smooth ride: big and small turbo actuators and the change over flaps. If any are seized or gunked up the vacuum system cannot operate them smoothly and accurately. |
04-12-2016, 06:16 AM | #6 | |
396
Rep 1,578
I am getting this code once a week even though the MAP is new. Boost pressure sensor signal interruption oKurzschluss to earth Code: 003F01 A few months ago I got some EGR codes when towing my 5000 lb boat but they have not returned. thanks |
04-12-2016, 06:18 AM | #7 | |
396
Rep 1,578
04-12-2016, 05:19 PM | #8 |
Rep 196
Basic function of EGR is to reduce oxygen for lower combustion temps - too much EGR and combustion is poor and lambda <1. The primary reason for a HFM on the diesel is to monitor EGR air flow. Easy test before troubleshooting the turbocharger vacuum controls. In any event I'd be logging about 20 air flow related labels.
