Free MHD I8A0S IJE0S E60 Demo Maps
04-12-2016, 03:35 PM | #1 |
469
Rep 4,392
Must be FBO or FBO+ (+ is upgraded inlets/outlet) with upgraded LPFP for E60 fuel.
If you are 6MT you MUST have an upgraded clutch or your clutch will start to slip. If you have a Jb4 remove it, more than likely you will not install it again . If you want to leave it on map 0 or bypass mode then that's on you. I require that you remove it as your going to be doing that anyhow. Demo maps will have a speed limiter cap and boost will be targeting 18-19 PSI If you want the speed limiter removed, more boost, custom tuned then you will have that option but not for free. So you get to "TEST" it, "FEEL" it, "EXPERIENCE" it for yourself how I tune these cars, and the drivability. So its not all about talk, its about proof. No bias, or I3ullshit talk. If your interested in a BQ Tuning demo map send me an email BQ@************* I need a list of your mods, your VIN, and if you have 6AT or 6MT transmission 6AT cars, if you have the Alpina TCU flash please let me know If you don't know what this is then dont worry about it No pump gas demos No demos for stock cars Guaranteed - 100% factory knock tables, not desynthesized, or altered in any way. Last edited by BQTuning; 04-12-2016 at 04:00 PM.. |
04-12-2016, 04:16 PM | #3 |
Jewel Runner
331
Rep 911
Gotta say, I'm a little jelly right now since I wont be FBO for a couple more months...
04-12-2016, 06:17 PM | #7 |
294
Rep 1,834
Drives: 08 E90 335xi TiAg
No option for stock DPs?
04-13-2016, 12:06 PM | #11 |
Rep 299
Drives: E92 335i SE 6MT
So you think stock down pipes can handle that sort of boost ? That would be the same sort of boost mhd stage 2 goes up to?
It's so tempting ! But I know DPs aren't exactly expensive anyway ... Sorry for thread hijack, good luck with demo promos ! Last edited by Rory; 04-13-2016 at 12:17 PM.. |
04-13-2016, 12:37 PM | #12 | ||
469
Rep 4,392
As far as a semi FBO car ie that has upgraded FMIC, air intake, and LPFP, running E60 with 18 PSI is not an issue. The map will need changes done to VANOS though. I've been down this path on many cars, including my own, my 335is and my Z4. Nothing though compared to what I did to the Z4. It was all stock with only K&N drop in filter on E40 fuel in which I was doing some R&D tuning on in the beginning http://datazap.me/u/buraq/dyno-stock...19&zoom=86-241 There was no problem with airflow running 18-19 psi, just crazy heat. This is my car though I punished. You will indeed need an upgraded FMIC, air intake be it CAI or DCI and definitely an upgraded LPFP to run my E60 demo map. CAI setup highly recommended though. Of course being catless allows more power up top, catted dps will restrict you. Last edited by BQTuning; 04-13-2016 at 12:42 PM.. |
lightmanek116.50 |
04-13-2016, 01:16 PM | #13 |
Rep 164
Email sent
• BMS Dual intake system • RB PCV Valve • BMS Oil Catch Can • BMS Oil Thermostat • COBB FMIC • COBB AccessPort V3 • Aerodynamic kit • M Package • Cp-e BOV •Cp-e 3" catless DP • Wedge performance stg2 map
07-02-2016, 07:24 AM | #15 |
Rep 96
I started off wit his demo maps about a month ago and they do feel awesome... Im finishing up my custom tune with him now.
If you have a DCT it is a no brainer... the ots stage 2 mhd maps felt a little violent on my DCT |
07-02-2016, 09:11 PM | #17 |
469
Rep 4,392
Yes, for all MHD supported I8A0S, IJE0S, IKM0S, and INA0S ROMs on stock turbos or upgraded turbos
I may not be able to get to it till days later as I have to focus on regular customers first, and then on free time send out demos maps. |
07-03-2016, 08:12 PM | #18 |
Major Private First Class
449
Rep 1,327
Drives: 2010 E90 335i M Sport
This is a hell of an opportunity! I went full blown Buraq and never looked back.
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
07-06-2016, 03:58 PM | #21 | |
469
Rep 4,392
Flash tuning only, I do not support the JB4 with BEF. If your meth kit supports flash only tuning then yes I can put something together for you but the JB4 must be out of the picture completely. Demo maps are exclusive only to MHD flash platform. |
