I can't find anything...
04-21-2016, 01:25 PM | #1 |
Rep 263
I'm trying to replace my vacuum lines but I can't find any helpful info. I've done a couple short ones by cutting the tube and peeling off as to not break the "nips". importantly I want to do the red line but can't seem to get enough room to work. I can barely see let alone feel where it attaches in the rear of the engine. hose #14 in the image on the linked page. After that I want to do hose #11 and the two that go over the top to lower passenger side hoses #9 (long ones).
http://www.realoem.com/bmw/enUS/show...diagId=11_4225 I'm using inner diameter 3.5mm silicone lines. (2011 335d M-Sport) Any advice and tip and even better how - to appreciated! ! |
04-21-2016, 01:32 PM | #2 |
Rep 291
As usually on diesels it is a tricky part.
I was trying to replace without seeing it with no luck. I had to unbolt plate with vacuum tank, and sensors, there are 4 - 10mm bolts inside plastic, not one you can see, one of them is completely pain in the ass to remove. That one i even put in garbage and left just 3 bolts. Also as precaution i would say inspect and may be replace hose on Exhaust Pressure sensor. |
04-21-2016, 01:40 PM | #3 | |
Rep 263
04-21-2016, 01:42 PM | #4 |
Rep 291
These 2 bolts holds the bracket, and you do not have to remove them, or you can but it will not help as there other bolts in the back which you will not be able to remove.
04-21-2016, 01:54 PM | #6 |
Rep 291
I am wrong, there are 3 bolts recessed deep inside.
Here the picture from the top, and you can also see the damage made by a burned hose, which cost 50 cents, and makes more troubles than should. |
04-21-2016, 02:02 PM | #7 |
Rep 263
Very helpful! I will definitely check out the hose. Once the bolts are out, do you have to completely remove the black bracket or whatever it is; or can you leave everything attached to it and just move it for space?
Sorry about all of the questions. |
04-21-2016, 02:06 PM | #8 | |
Rep 291
I had to remove it just now, to replace even it works fine with my fix, and also i am going thru DPF removal. |
04-21-2016, 02:10 PM | #9 |
Rep 263
sweet! I have about 10000mi. Til I'm out of warranty/June then I plan of doing the delete of everything. I've been using an xacto knife to cut and peel the lines off... hopefully there will be enough space... what technique did you use?
04-21-2016, 04:22 PM | #10 |
Rep 291
I was puling out one piece of tube, use it as template to cut the new one, and put it back.
04-21-2016, 04:25 PM | #12 |
Rep 263
You just pulled the tube off? without breaking anything?
so far I've sliced the lines and kind of peeled them off then cut new ones y he same length. This is all I've done as I got frustrated with the red line and can't afford to break anything as I have work in a day or so. |
04-22-2016, 07:54 AM | #15 | |
Rep 1,288
04-22-2016, 08:53 AM | #16 |
Rep 2,410
This is very good info guys, and thanks for taking the time to post. It appears this is something we'll all have to deal with eventually.
Has anyone, after having to replace these lines, choosen to completely change the routing of those hard to reach hoses? I'd rather have a longer hose route that's more easily accessed than a shorter route that's a pain to change out...
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods |
04-22-2016, 09:24 AM | #17 |
Rep 234
I changed my red and blue hoses recently as well with silicone hoses. I cut the new hose to similar length but gave it a bit more slack. Still getting code p0029 for underboost though.
04-22-2016, 09:29 AM | #18 | |
Rep 1,288
For those with an ABC delete, you're essentially down to an accumulator and 3 pressure converters. All of which can be remotely mounted in a more cozy environment. Perhaps up within the cowling on that side? Then while at it if one were really innovative, splice in a vacuum gauge to alert you to any issues. |
04-22-2016, 02:20 PM | #19 | |
TL/DR
57
Rep 234
Drives: 2009 335d Sport
http://www.42draftdesigns.com/6-port-vacuum-manifold/ |
04-22-2016, 03:10 PM | #20 |
Rep 263
I'm about to start working on the lines again and thought about rerouting the lines but if I increase length, will that have any negative effects?
