M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > 1200 Mile Maintenance - Does anyone know??
      04-24-2016, 06:40 PM   #1
Olgunan
Olgunan's Avatar
35
Drives: 2016 BMW M2
Gents, there seems to be a lot of rumors out there about what actually happens during the 1200 maintenance on the M2. Does anyone have facts or are we going with speculation? I know that there are couple of people who have had this done thus far, and I am coming up on mine. Just wondering what it is I should be looking for...are there different modes in iDrive, is there a new tune, does Jeremy Clarkson deliver the car back to my driveway with Gigi Hadid in the passenger seat for a one nighter? All valid questions...
Appreciate 4
      04-24-2016, 11:38 PM   #2
OrangeCrush
OrangeCrush's Avatar
1236
Drives: VO 1M #513/740
I was just looking at this in the manual. All I found was oil change and differential fluid change. Does anyone know the difference fluid part number?
I stopped there and didn't look for any tuning.
Current
AW BMW M2
Past
VO BMW 1M
mitoda66.50
      04-25-2016, 02:55 AM   #3
Yellowflash21
Slovenia
370
Drives: M2
Got info from my dealer regard break-in period.
All M cars that got released from the factory are using totally different type of Oil compared to the one that is replaced on every scheduled maintenance period.
That's why they have set 1200 miles services.
      04-25-2016, 06:55 AM   #4
MR.
MR.'s Avatar
4398
Drives: BMW M2 CSL Turbomeister
For your information... This is what they do:
- Oil change in the engine
- Software change allowing you to use burnout mode
- General checking the car and seeing if they are any early problems with it
Other than that nothing else. Transmission oil fluid is not replaced.
MR
Appreciate 4
      04-25-2016, 07:09 AM   #5
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
MR
Ironically I just a message to my sa before seeing this post asking him what they do and how long of a wait for the car. Will see what he comes back with and if it matches your list. Also, asked him if he could disable asd even if it was 'off the record' that they did it.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
      04-25-2016, 07:19 AM   #6
MR.
MR.'s Avatar
4398
They could not do that officially, but they can do it. My dealer has offered it as well.
MR
      04-25-2016, 08:58 AM   #7
OrangeCrush
1236
MR
The manual stated that differential fluid is changed. Is that true?
Current
AW BMW M2
Past
VO BMW 1M
      04-25-2016, 10:14 AM   #8
MR.
MR.'s Avatar
4398
Not sure, double check is. I only checked it for M-DCT.
MR
      04-25-2016, 10:35 AM   #9
Pyrat 2
Pyrat 2's Avatar
MR
Here is what he said.
"The 1,200 mile service includes an oil and filter change, rear axle fluid change and software calibration to up rpm limiter and speed limiter. I did some checking and I have not been able to confirm that we can shut off the active sound through the factory diagnostic equipment, it might end having to be done with outside coding."
      04-30-2016, 05:43 PM   #10
Pyrat 2
Pyrat 2's Avatar
Just had mine performed today. Confirmed oil and diff fluid change. Also removed rpm limiter.
      04-30-2016, 06:51 PM   #11
Ex-MINI
BMW Newb
Ex-MINI's Avatar
581
Drives: 2016 LBB M2 DCT
Were they able to code out the ASD?
PGHM228.50
      04-30-2016, 07:03 PM   #12
Pyrat 2
Pyrat 2's Avatar
Nope. Their expert coder wasn't in. They said they would get back to me on Monday with a definitive answer. Also, asked them to check if the could code the backlight on. On the ASD I ordered a bypass cable. Should be here this week as its in transit via usps right now.
      04-30-2016, 07:54 PM   #13
twboy1999
Drives: 1994 honda accord
So what's the rpm limit before the 1200 service
2019 M2 HS 10000km and counting
      05-01-2016, 09:10 PM   #14
Kantalias
Drives: 2016 M2
That's what I'm saying! I wouldn't be so freakin' paranoid if I knew I was limited.
      05-01-2016, 09:17 PM   #15
cole3488
Drives: e92 m3
I've got mine on Friday I'll ask
      05-01-2016, 09:35 PM   #16
Pyrat 2
Pyrat 2's Avatar
5500 before break-in. Not too hard to keep it below that. Also, you are to keep the top speed below 106. On a 1000 trip back from Spartanburg on some country roads in the Midwest that required some restraint (see the pleasant sheriff I met in the picture).
      05-02-2016, 04:52 PM   #17
Yellowflash21
Slovenia
370
Drives: M2
Just completed mine 1200 service this morning.
They have put 0w-30 oil as its seems to be better for the first oil change but also 5w-30 is fine and I will look to put it after my first track day.
The car is pulling the same as before, and I'm very easily losing traction even in 3rd gear.
So guys, just push it 80% hard and you shouldn't have any issue.
      05-02-2016, 10:45 PM   #18
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
MR
Did he really say "axle fluid"? I was wondering if my seat heater fluid was low all this time. I was right..
      05-06-2016, 03:59 PM   #19
OrangeCrush
1236
What does your receipt say about the limiter coding? Mine doesn't really say anything but I know there is no limit considering it shifts at 7300 rpms.
Current
AW BMW M2
Past
VO BMW 1M
      05-10-2016, 09:55 PM   #20
Kantalias
Drives: 2016 M2
So it's just coding and not an ECU refashion, right? I've got an ASD bypass harness and my rear view mirror is disconnected at present and this makes me nervous: http://www.2addicts.com/forums/showthread.php?t=1260271.
      05-12-2016, 08:23 PM   #21
///M2-PILOT
M2 PILOT
///M2-PILOT's Avatar
Drives: 2016 ///M2 HEA LBB M-DCT
Oil (0w-30) and rear diff fluid change. They also turned on the launch mode and did a general vehicle check.
///M2 - LBB - EXEC - M-DCT
      05-13-2016, 09:35 PM   #22
Kantalias
Drives: 2016 M2
Yep, oil and diff fluid on a DCT. Resetting the maintenance indicator enables launch control and smokey burnout (no coding, no ECU reflash). "Vehicle safety check" failed to notice that my mirror was completely non-functional.
Here's the full list of activities done during the running-in check:
m2
