2011 335d Vacuum Line Replacement Tips, Tricks, and Photos
04-28-2016, 08:35 AM | #1 |
Rep 263
So i finally finished changing out the Vacuum Lines/Hoses whichever you prefer to call them and let me say, what a PITA!!! I decided to stick with 3.5mm inner diameter and use silicone lines as replacements. Here's my tips/ tricks.
EST. Time From Start To End: ~5 hours (included several non-working minutes to swear and ponder and swear again) Tools: Flashlight & cellphone light, various sockets, extensions and most importantly an x-acto knife with a curved blade (Shown Below). Replacement Product: http://www.amazon.com/HPS-HTSVH35-RE...ne+vacuum+hose ** I ordered Red, Blue, and Black all in 10' lengths. I wanted to be sure to have enough and its only ~$60 for all. Brief How To: 1) Remove the engine cover, cabin air filter, etc. 2) Remove air intake duct above radiator by remove three screws. Two are on top, one is in front. 3) Remove air intake box, unplug MAF and other misc. connectors to all removal. 3) Take a deep breath because the next steps suck! 4) Using the X-acto, I sliced the old line where it covers the various nips and usually attempted to slice a "V" pattern. For example: The end of the existing line now has two slices that meet and intersect near the tip of the nips within the line. 5) To remove the Red Line in the rear of the engine, I removed the black bracket that has several components mounted to it. there are three nuts recessed into the mount. I used a socket attached to a extension that i slipped into the recessed area then connected the wrench. This technique is essential for the nut nearest to the firewall. Once you remove this one, put if for safe keeping, as I, once completed, did not put it back on as I felt two were enough. 6) As for all lines, once removed, I cut a matching or slightly longer replacement piece. I cut some linger because the new lines have a bigger outer diameter, as to relieve stress on the tight turns that certain lines had. 7) Replace all parts removed and your done. ** Note: I did notice that due to the bigger outer diameter lines the engine cover was more of a "tight fit" that I believe is due to the molded foam. With a little "pressure" the engine cover does go back on with no issues. #1 Tip) Patience, Time, and a good vocabulary of swear words. I did not do the line that is under the Air Intake Box that wraps beneath the engine as I could not feel an end, however I will be putting the car on some stands and removing the under body cover and replacing that one as well. It should be pretty easy and straight forward. Let me know if I can provide any further details. I started to make a video but became frustrated with the Red line and never completed the video. Hope the photos help! (They had to be resized for the forum so hopefully they aren't too distorted. They are also not in much of an order, except for the finished photo) Last edited by Hockey13; 04-28-2016 at 09:02 AM.. |
13
04-28-2016, 05:20 PM | #2 |
Rep 1,192
Thank you very much for this thread and write up! It are posts like this what makes this forum great. I guess I have two preventative maintenance jobs for this summer: Vibration damper pulley and this!
Cheers mate! Last edited by Mik325tds; 04-29-2016 at 06:10 PM.. |
04-28-2016, 05:37 PM | #4 | |
Rep 263
04-29-2016, 07:17 AM | #7 |
Rep 1,288
When installing the engine cover. Take caution not to inadvertently crush a vacuum hose. There are several possible pinch points.
05-14-2016, 01:43 PM | #8 |
Rep 460
Hockey how did this setup result? Did you have codes or leaks prior to this install?
05-14-2016, 04:44 PM | #10 | |
Rep 263
Once the PITA job was done everything was still good with no known issues. |
05-14-2016, 04:47 PM | #11 | |
Rep 263
03-21-2017, 10:02 PM | #12 | |
Rep 1,157
03-21-2017, 10:10 PM | #13 | ||
Rep 263
05-05-2017, 01:34 PM | #15 | |
Rep 263
jomiri6.50 Chief Orman669.00 |
05-05-2017, 02:02 PM | #16 |
Rep 1,157
I bought OE vacuum line from fixmyvw.com. I bought 3 yards(9 feet) and that was plenty. Absolutely get a curved xacto blade. And there is a banjo bolt on the exhaust manifold. If you have to mess with that any, be sure it is heated up. Mine was cold and when i cracked it off, the bolt stripped. Had to get it towed to a shop.
09-10-2017, 07:48 PM | #17 | |
75
Rep 392
535D Xdrive DUDMD Stage 1
x5d e70 DUDMD stage 2 tune |
09-11-2017, 06:27 AM | #19 |
BRR tuned
220
Rep 646
It looks like he had a typo... he said "I think it comes in 10' "
I think he meant to say I think it comes in at 10' me personally I bought one 10ft bag and it is enough. I still have a few lines to replace and it looks like I have plenty to complete. 3.5mm ID 10ft |
02-20-2018, 02:44 PM | #22 |
10
Rep 44
Drives: 2011 BMW 335D
Anyone use Verocious Motorsports vacuum hose in their D? I saw it all over the 335i hose replacement thread. Concerned a little by the notice on their site that says "Silicone hose is NOT FOR USE IN FUEL OR OIL APPLICATIONS".
https://www.verociousmotorsports.com...ld-by-the-Foot |
