Installed mechanical boost guage. Boost is uneven?
05-01-2016, 10:20 AM | #1 |
393
Rep 1,578
I am trying to troubleshoot an intermittent hesitation. The only thing I know now is that boost fluctuates 5psi up and down when the hesitation is occurring. The hesitation is so fast that the data logging apps are not useful. To help collect info I have installed a mechanical boost gauge with a T off my boost sensor. See video below of boost gauge in action. This is what I get accelerating gently on the highway.
So far I have changed all vacuum hoses, actuators, boost sensor (twice), red charge hose and seals on charge hose on intake side. It is an 09 E70 35d w/ 45k miles. Thanks |
05-01-2016, 11:18 AM | #3 |
798
Rep 1,633
Can't see speed or rpm in the video. And the video moves around alot. Can you fill in the blanks, so we can understand what the issue is? The boost gauge will move as you drive.
05-01-2016, 12:22 PM | #5 |
393
Rep 1,578
I am accelerating gently and the boost is jumping around. It should be even and is even when the issue is not happening. In the video I am in 6th accelerating from 55 to 65. The boost should go to 20ish and stay there. Also, the needle on the gauge should not be vibrating as mush as it is. I will try to get a better video later today. thanks
05-02-2016, 08:08 AM | #10 |
393
Rep 1,578
Here is a better video that shows the bigger 5 psi jumping around. Still think it is PWM? This was with a small even attempt to accelerate. I will try the cotton trick that probably will get rid of the needle small 1psi vibrating. Thanks
05-02-2016, 11:12 AM | #11 |
Rep 579
Boost pressure is subject to instantaneous fluctuation on engine demand, unlike things such as fuel or oil pressure. Snubbing it will only reduce the accuracy and timing of the reading.
05-02-2016, 12:13 PM | #12 |
393
Rep 1,578
Agreed, but the fluctuating is intermittent. Most of the time the boost is not bouncing around like that. When the boost bounces around, the power disappears and it does not run well.
05-02-2016, 02:27 PM | #13 |
Rep 2,210
Dont those both have a blow off valve type bypass which would allow the boost to be released very quickly from the charge side? 335d doesnt have any mechanism in the intake for releasing that pressure so it would have to rely entirely on the turbo speed increasing and decreasing. It would surprise me that the turbo can speed up and slow down fast enough to replicate those boost spikes, especially the slow down part.
05-02-2016, 03:21 PM | #14 | |
864
Rep 642
05-02-2016, 03:43 PM | #15 |
Rep 2,210
Interesting. Seems like a bit of a crazy idea, how do they regulate boost spikes from closing the throttle? Or does the computer just not allow the throttle to snap shut if boost is high?
05-02-2016, 04:19 PM | #16 |
393
Rep 1,578
Here is a much better video. The X5 is actually surging forward each time the boost goes back up. One other symptom I forgot to mention is highway MPG. I get 21 on the highway but can get 22 around town. Something is not right and lack of codes has me guessing. thanks
05-03-2016, 06:11 AM | #18 |
393
Rep 1,578
Yes it is stock. I can try disconnecting the EGRs. I can disable the LP by removing the vacuum hose. For the HP one is it best to just disconnect the electrical connector? It seems to have less power when I do that. I am also going to check out the diverter valve is that is the only thing I have not looked at yet. thanks
05-04-2016, 08:09 AM | #19 |
Rep 579
05-04-2016, 12:28 PM | #20 | |
798
Rep 1,633
05-04-2016, 01:46 PM | #21 |
393
Rep 1,578
Agreed. Can Rheingold cycle the throttle or bypass so I can visually inspect? I unplugged the throttle for my drive home from work and it did not hesitate a single time so this is progress. I am now unsure if the throttle is bad or just reacting badly to some other sensor input. Others have had oil get in the throttle to damage the electronics so I probably will take it apart next.
05-05-2016, 05:38 PM | #22 |
393
Rep 1,578
Just did another quick test. Disconnecting the air mass meter and leaving the throttle connected also makes the issue go away completely. More power and less jerking around. I can't wait for it to run this way all the time. I have a feeling disconnecting these disables the EGRs and I should check those out next.
I tested the throttle with Rheingold and it passed. The engine did stall when the test started the first time and I am unsure if that is normal. It barely kept running for the second test. Thanks |
