Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > INPA on our M57
      05-01-2016, 11:48 PM   #1
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
INPA on our M57
Hey Guys,
I know this is a question more for the BMW coding board, but i have run into what appears to be an M57 specific issue, so I thought I would try here first.
I am not able to get INPA working after following the instructions by wildcatcrazy. I even worked with him a bit directly to see if we could get it figured out to no avail.
Who has INPA working on our cars? I am pretty sure there are folks out there who have. If i can get it figured out what is needed, wildcatcrazy will update his instructions/files and we all will benefit.
Thanks.
      05-02-2016, 02:26 AM   #2
Yozh
Yozh's Avatar
870
Drives: 2011 335d M-Sport
It's M57 that our engine is, may be that is a starting point?
      05-02-2016, 03:36 AM   #3
Hockey13
Any reason your not using reihngold?
      05-02-2016, 04:03 AM   #4
Len_Beach
Drives: 435d
I have it partially working but found it frustrating that certain elements still didn't work.
Therefore I turned to Rheingold.
      05-02-2016, 07:36 AM   #5
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
LOL...oops, yes it would be.. Corrected. Thats what I get for typing late and not thinking enough.
      05-02-2016, 09:32 AM   #6
Lexx.md
Drives: e90 335D
If you can share with installation package which works, i have tried some from internet with no luck.
      05-02-2016, 09:33 AM   #7
Lexx.md
Drives: e90 335D
Thanks.
Did you read this?
http://www.e90post.com/forums/showthread.php?t=1206390
      05-02-2016, 09:42 AM   #8
Hockey13
I'm attempting to install a newer version. I'll work on It Wednesday and once it's good to go well talk
      05-02-2016, 09:44 AM   #9
Lexx.md
Drives: e90 335D
This is exactly what we need, here if you can find something working with some instructions will be very appreciated here.
      05-02-2016, 09:44 AM   #10
Hockey13
deal!
      05-02-2016, 09:54 AM   #11
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
Originally Posted by Lexx.md View Post
Hey Lexx, I had read through quite few threads but hadnt run across that one yet. Ill give a look at it tonight and see if I can get anything figured out.
When I tried 808's install it failed completely on my win10 machine, so I ended up getting a different install package from wildcatcrazy's thread which installed just fine. And Im able to do coding and stuff, just cant do diagnostics on my engine. Which is the reason im fighting this thing to begin with.
I will read through this closely and let you know what I figure out. Thanks!
      05-02-2016, 03:32 PM   #12
Len_Beach
Drives: 435d
This will get you a working version of Rheingold.
Google rutracker Rheingold 3.47.10. That is a fully working version of the software. There are newer versions but they require an earlier version such as this to install.
To install; Google car technology 3.44 and firstly follow the instructions on here to install. Then use the instructions in the configuration manual that came with the download to finish it off.
It sounds complex but it's pretty straightforward if you follow the instructions step by step.
      05-02-2016, 04:25 PM   #13
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
Yeah, there is.....Ive never heard of it Apparently its something I should look into though huh?
      05-02-2016, 05:59 PM   #14
Hockey13
Hopefully others can confirm to the following:
AFAIK rheingold took over inpa for e and f cars (ie. e90). Prior to that there was inpa D (diagnostics) and inpa p (programing ie. coding). what I'm not sure about is the latest rheingold version and the latest database (correct term?) files for it/ our cars.
      05-02-2016, 08:54 PM   #15
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
Got it working with that thread, thanks Lexx, now to learn German.. j/k...I am trying to figure out this rhinegold thing... But I may just break down and get a BT cable instead.
      05-02-2016, 09:36 PM   #16
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
Yeah, so you lost me from the start Len..... I found the rutracker page, but its definitely in a language i am not familiar with. Is my only option there to torrent the file? no way to download directly? and its really 9+ GB compressed? Wow. So after i download and install that....I go to this other place for instructions...then back to configuration manual from original download to finish?
      05-03-2016, 01:41 AM   #17
Len_Beach
Drives: 435d
You'll need to use Google Translate from Russian to English. I found it was easiest to register first and get used to the site then use Google translate to find the link.
I could only find the Torrent; I guess the size is the reason there's no direct link. 9Gb sounds about right too.
Once you have completed the downloads; use the other site for the bulk of the instructions to install then the final element using the manual in the download.
      05-10-2016, 12:12 AM   #18
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
Rheingold
I got Rheingold up and running, but honestly I have no idea what its capable of or what to do in here.
So far all I have seen is error codes and service plans.... I assume there is more diagnostics but i dont have a clue where/what/how.
Anyone have a good "how to" on it?
